Question about IBM ThinkPad R40 2681
IBM R52 1860-A36 Giving thermal sensor error - IBM ThinkPad R40 2681
Thermal sensor error.
Posted on Dec 21, 2011
  • 2,567 Answers
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Posted on Sep 28, 2010
  • Mohamed Omran Sep 28, 2010
    Sorry. I pasted the wrong text into your problem.
    Here is the correct solution:
    This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
    You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
    If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Location of thermal sensors on ibm t43
The heat sensor is mounted on the motherboard. The problem is most like with the fan being block by dirt or debris. See my answers here:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=8&fml=0&brd=228&p=2&thid=24357750
May 08, 2014 | IBM ThinkPad R40 2681
When i switch on my IBM thinkpad R51, it displays the THERMAL SENSOR ERROR and then it shutdown. Where is the location of the sensors are on the motherboard.
Usually under the CPU, but it appears you may have a faulty fan/heatsink or its not working at all, if you can direct a fan at the thermal vent and it stays on longer then that will be the issue, i would recommend taking to to a local repair tech unless you can do it yourself.
Jan 05, 2014 | IBM 2885K4U Thikpad X32 P M 7552ghz 512mb...
T410 thermal sensor error
I have seen this error on older Thinkpads its was a processor fan problem, when you boot the PC can you head the internal fan spin up?
Jan 04, 2012 | IBM Lenovo ThinkPad T410 Notebook PC
WE HAVE A DATAMAX CLASS PRINTER AND IT'S GIVING ME AN ERROR " TOP F FORM FAULT" WE DO NOT HAVE THE MANUAL. CAN YOU PLEASE HELP? THANK YOU
Most likely problems:
Wrong sensor set in the media type area. Gap, Reflective.
If the incorrect meday sensor is set, the unit will give a TOF error.
If you hae pressed the feed button and kept pressed for at least 4 labels, and it does not automatically calibrate, check the type of sensor.
If you still get error, and the correct sensor is set, do a complete calibration.
You can downlad the user manual at Datamax-ONeil Web site.
Feb 24, 2011 | Datamax I-4208 Thermal Label Printer
Have an error: security PAL not detected on a IBM 4400 printer
How do I fix a FPGA error on a 4400 thermal printer?
Dec 16, 2010 | IBM 4400 Thermal Printer
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
Thermal sensor error on fujitsu
Don't worry. I'm sure it will be fine, as long as it's not over heating or smoking. lol. But seriously, you should be able to disable that error in Bios under one of those options. If you are still having problems contact customer support for help.
Thanks,
Brandonmxb
Dec 09, 2009 | IBM ThinkPad R40 2681
Chcek www.thinkpad.com for a service manual.
Sep 15, 2009 | IBM ThinkPad R40 2681
Error ribbon in is flashing in Z4Mplus printer althought its set to direct themal
this shouldn't stop it printing, could be a dirty sensor - under the printhead. it is a printhead open/ribbon sensor. try giving it a clean (its not the red one). if that doesn't work you can turn the ribbon sensor up to 100% in the menu. that usually stops the error if all else fails
Apr 27, 2009 | Zebra 105SL Thermal Label Printer
Thermal Sensing error
"Thermal sensor error" just means "Broken fan".
Jan 11, 2009 | IBM ThinkPad R40 2681
IBM ThinkPad R40 2681 Logo
328 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
