Question about LG WM-2277HW Front Load Washer
After being switched on it doesn't get started.
  • LG Master
  • 17,129 Answers
You will need to check the voltage that is available in the inlet valve, the waterlevel sensors , the motor and the drain pump/valve to establish if the program controller is working.
If not the controller is faulty.
Posted on Sep 28, 2010
Nokia 5130 switch on problem
remove switch.
and short switch point to ( - - ) & ( + + )
u can on your cell without switch
Jun 23, 2013 | Nokia 5130 Cellular Phone
Truck has power but doesn't start. Starter doesn't click either
Have you checked the circuit between the key switch and the starter ?
There should be a starter relay and a neutral safety switch involved.
Feb 25, 2013 | 1994 Toyota Pickup
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
Jun 17, 2017 | 2003 Volkswagen GTI
1994 Toyota Camry doesn't start without shaking
sounds like it having trouble starting. when was the last tune up ,and are there any codes on.
Nov 03, 2012 | Cars & Trucks
1988 Trans Am will not start when ignition is turned all the way.
Take a test light to the small wire on the starter and have someone turn it to the start position. If the light lights up and the engine doesn't turn over, I would suspect the starter itself. If the test light doesn't light, try it in neutral and repeat test. If it still doesn't light up, it may be the PRNDL switch or the ignition switch itself.
Sep 22, 2012 | 1988 Pontiac Firebird
88 s10 2.5 is getting spark and fuel but will not start with key switch
so it starts if you pop start it?if the engine turns over but doesn't start then its a bad ignition switch if it does not crank over see if you have power going to the small wire on the solenoid if no check the safety switch and wires at the switch if there is power to the small wire but doesn't turn over then the starter is bad
Aug 31, 2012 | Chevrolet S 10 Cars & Trucks
1992 Toyota previa fuel pump cutoff switch
This make and model doesn't have a fuel pump cut off switch, the switch is only activated by an impact of 3 G's or more on cars and trucks that do use the switch. Spray starting fluid into the air intake of the engine, if it doesn't start you do not have a fuel pressure problem. Lots of things can keep a car engine from starting, you never mention any tests for fuel pressure or spark or proper valve timing (cam drive belt broken or jumped)
Aug 08, 2012 | Toyota Previa Cars & Trucks
Ge JES0738 LED display is fine but turntable doesn't work, microwave doesn't start. Is it a fuse issue?
No! from the description it is one of the door switches that has become defective. The solution, all the door switches need to be tested to find the bad one.
Jun 13, 2012 | GE Microwave Ovens
Bike will not start, have lights, etc., no sounds at all, happened several times before, took to dealer they could not find anything wrong, bike was returned to me, started and ran fine, now it has...
Might be a faulty side stand lockout switch. They're subject to a lot of wear, tear and grime and tend to wear out. So your bike thinks the side stand is down when it isn't locking your bike out so it won't start. Failing that it may be a faulty neutral switch, again the bike doesn't know it is in neutral so doesn't start.
I am going to state the obvious also, is your main kill switch turned on?
Sep 19, 2011 | 2005 Suzuki Boulevard C90
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
LG WM-2277HW Front Load Washer Logo
23 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
