Question about Kenmore Elite Oasis 6808 Electric Dryer
My dryer door keeps opening while its running
  • Kenmore Master
  • 43,501 Answers
you need a new door latch...
Thatis not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 28, 2010
mreid542
  • 166 Answers
SOURCE: timer motor keeps running on dryer
sometimes as a timer gets older the timer motor will get a little loud. timer motors run even when the door is open. if the timer advances to off and everything works fine you don't need to worry about it.
Posted on Nov 20, 2008
  • 124 Answers
SOURCE: Dryer keeps running after the door is open. Is
Hi.
Yes door safety switch may be faulty or stuck.
Normal for them to go out over time & usage. Switch is usually $5.00 to $20.00 labor well you can guess as usual more than it should.
Another possible problem could be wire shorted. But that would be a rare occurrence.
Posted on Mar 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: dryer door
The dryer door catch and latch assy is worn and needs to be replaced.
See this link to see which of them matches your dryer: http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Door-Latch-Kits/index.aspx
Any local appliance parts supply center will have this part in stock. It is howe3ver best that you take your "complete model number" with you when you go to get the replacement part. They are under $3.00 in
cost.
Use a knife blade to unlock the opposing plastic retaining tabs on the old part for removal. Make sure you change both pieces. The one in the chassis and the one in the door.
Thanks for using FixYa.
Kelly
Posted on May 16, 2010
TheMobilian
  • 8220 Answers
SOURCE: when one opens door ------dryer keeps running
Simple repair. e45a747.jpg5fc411d.jpgf1e9000.jpgIf you gonna remove the front to do the repair I suggest you lift up on the panel to keep from damaging the clips that hold the bottom secure46c7a66.jpg
Posted on Jul 24, 2010
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Lg dryer wont turn off
If the dryer continues to run when you open the door you will need to replace the door switch. Here is the part to order.
Nov 03, 2012 | Dryers
When one opens door ------dryer keeps running
Jul 24, 2010 | Roper Dryers
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
Mar 25, 2009 | Dryers
The door switch is probably stuck or defective.
Mar 11, 2009 | Frigidaire FDG546RE Dryer
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Timer motor keeps running on dryer
Nov 19, 2008 | Dryers
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Kenmore Elite Oasis 6808 Electric Dryer Logo
263 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
