Question about Panasonic Televison & Video
Hi Can I modify DMR EX 88 to be able to decode HD (change over decoders)? AS
  • 1550 Answers
SOURCE: Error message Unable to decode HD
check if the hd is acceptable in your player
check if that settings is activated
Posted on Apr 26, 2009
SOURCE: decode
i lost my password
my code is: 21344 13898 6789 8507
Posted on Jan 15, 2010
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
  • 11800 Answers
SOURCE: Is it true that my
No, you can't decode them. Actually decoding them is considered piracy and against the law. That unit like the vast majority of them, if for the recording of the channels that are not coded , or, if they are coded , you have permission to record them because you have bought it from the channel owner.
Posted on Oct 10, 2010
geemarie
  • 876 Answers
SOURCE: I have bougth a HD digital decoder. It is
Your audio must be hooked up incorrectly. Take alook again at the back of your TV and the decoder. Does the decoder have more than one set of incoming connections? Does the television have more than one set. Please tell me exactly what you have hooked up to what (names of connection ports and color of the wires). Thank You.
Posted on Jan 02, 2011
Auto format decode means?
HI,
There are so many audo formats like Dolby Digital Decoding, Dolby Digital EX Decoding, Dolby Pro Logic Decoding, Dolby Pro Logic II, Dolby Pro Logic IIX Decoding, dts 96/24 Decoding, dts Decoding, dts NEO:6 Decoding and dts ES Decoding Stereo etc. What ever the AVR get a digital input It will decode the format and convert the same While it in the Auto format mode. If auto format is not selected it will convert the same in to stereo.
Ajin
Feb 09, 2012 | Audio Players & Recorders
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Need a manual for id tech series 88 decoder
Here you go sir
http://www.barcodediscount.com/pdf/IDTech/decoder.pdf
Please rate my solution, I showed the fastest answering time just for your needs. Thanks in advance :) Alex
Apr 13, 2011 | ID Tech IDTech Series 88 and 98...
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Message appears unable to decode HD channels
DMR-EZ47V and EZ48V models do not feature a built in HD digital tuner - it is only SD - hence the reason it cannot decode HD. It is a model/design limitation; not a fault.
Jan 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Is it true that my fairly newly purchased product Panasonic DMR-EX79 is not able to decode all HD channels. This was an expensive unit and bought it for HDD reasons as well. Can you please advise if I...
Oct 10, 2010 | Panasonic Televison & Video
Feb 07, 2010 | Panasonic Televison & Video
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Watching another channel while recording
Hi there! Sorry but you can't unless you have My Sky/HD recorder. The sky decoder is simply a one channel watch decoder. You can only record a sky channel and watch the channels normally provided via your VHF and UHF aerials connected to the decoder or vice versa.
My Sky fixes that although you cannot record to a dvd disc on this thing and the privilege comes at a price of course!
Aug 03, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Televison & Video Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
