I need the instructions on how to use a HAIER AA 6KG Washing machine Modl number: HW-C1260TVE-U
SOURCE: i have the HAIER HW-C1260TVE-U
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Posted on Jun 13, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Hoover HNL 6166 6kg A+AA 1600 washing
Hi.
It is very likely you need to replace the motor brushes. These are the electrical conections in the motor that wear after a time. They are fairly cheap, uses-replaceable, and available from online appliance specialists.
Turn off water and unplug before removing top/ back pannel to access motor. ***** CHECK MOTOR TYPE BEFORE ORDERING PARTS ******
Posted on Sep 30, 2009
rickead1
  • 1998 Answers
SOURCE: My haier automatic washing machine model number
Try this out
HOW TO FIX ERROR 7 PROBLEM!
This problem is quite common on these machines, especially just after the machine has been moved. As a previous poster has said, Err 7 is a motor error. It is usually because the electrical connector has become detatched from the motor. Here is how to fix it.
* First of all, PLEASE unplug the machine from the wall socket! And switch off the water supply too!
* Pull the machine out from under the counter, and turn it so that you have access to the back of the machine.
* Remove the 3 phillips screws that secure the back plate. You are only removing the small plate immediately behind the drum, not the whole back panel!
* Look through the hole you have just created by removing the panel down towards the bottom of the machine. You will see the motor. Hopefully you will also see a 7 way connector not connected to anything, and a 7-way socket on the motor! (7 way means that it connects 7 different wires!)
* Plug the connector back on to the motor. Don't worry, it will only go one way round, so you can't get it wrong. If the connector looks like it is connected, give it a little wiggle and a push to make sure it is fully home.
* Replace the the small back panel, taking note that the top of the panel goes BEHIND the main back panel, and the bottom of it goes IN FRONT of the main panel. (This could be the other way round, I can't remember!)
* Push the machine back under the counter, making sure that it is level (level it up by turning the 2 feet at the front of the machine until it doesn't wobble), reconnect the water and plug it in to the electricity supply.
* Turn the machine on and attempt to operate the machine. (Top Tip: Select the wool or quick wash to test the machine, otherwise you will have to wait 3.5 hrs for the machine to go through a cotton/linen wash! Unplugging the machine won't help, because it remembers where it was when it gets a power cut!)
hope this helps
Posted on Jul 14, 2010
caroldon
  • 17130 Answers
SOURCE: hi, i have a haier
The cost depends a lot on the location you are in but not to worry this seems to be a mechanical fault and all what is required is good skill to remove the assembly and check , replace the bearings, check the shaft, bushes, seals for wear and reset.
With a manual check you can observe the wobbling of the drum and will prove that this is not steady due to the failure of the mechanical system comprising the spares mentioned.
Posted on Apr 01, 2011
  • 6277 Answers
SOURCE: My Haier 6kg AA washing
Hi Carys from retired Englishman in SW France,
For Haier error code 1 states 'door is not properly shut 20 seconds after program has started'
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
My Haier 6kg AA washing machine keeps coming up with error code 1 what's the problem?
John C
Aug 14, 2011 | Haier Washing Machines
Hi, i have a haier AA 6kg washing machine, and the glass door is being rubbed by the metal drum inside causing it to spark inside the machine and mark all my washing, how do i fix this problem? is it the...
Apr 01, 2011 | Washing Machines
Trying to set date on fossil watch #691464401344
The number you quoted does not look like a modl number (usually in the form AA NNNNN).
If you go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html , you will find some instructions. Choose the one that fits your watch and download the instructions.
May 10, 2010 | Bulova Watch
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
Jan 08, 2009 | Haier Washing Machines
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
