Question about LG Shine KE970 Cellular Phone
My phone stuck on vibrate
My phone is stuck on vibrate and it will not activate on to general. i have even tried to scroll down on the normal setting and it says complete but does not change.
what else can i do
Ben
    Brigadier General:
  • 7,752 Answers
You need to take the phone to your mobile center and have them either reflash the phone or replace it with a new one.
Posted on Jun 13, 2008
Lg 220 phone vibates buy does not ring
Open the menu and select settings, Open and scroll to select tones. Now check and see if the settings are activated only on vibrate, if so you can select to tone and vibrate or tones only.
If there is no tone even after this is selected this could be failure of the buzzer unit.
Jul 05, 2012 | LG C 2200 Cellular Phone
No sound on incomming calls
Hi,why it does not ring out is because,the ringer is damaged..and it needs replacement. Before you replace it,you can clean up where the ringer is,there might be dirt stopping it to work.But you have to unscrew the phone to see where the ringer is.
Please if you have no knowledge about the phone,you can contact a skillful personnel for assistance.
Before that you can trythe below step,might just be a setting problem.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Have a nice day.
Sep 19, 2011 | Nokia C3 Cell Phone
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
Jun 04, 2011 | Nokia C3 Cell Phone
My Nokia 6131 has stopped ringing - it just vibrates when there is a call/text. I haven't done anything different. It's not on silent and I've tried resetting to factory defaults. Any suggestions?
its like the user profile has changed to silent
All you have to do is....
go to the settings on your mobile phone, scroll to profile and select it, click on general or loud, select personalize,check the incoming alert mode and see if it is set to ringing,scroll down and select a tone for the alert then save. after which activate the edited profile as the profile in use..
hope this helps
Jan 25, 2011 | Nokia 6131 Cellular Phone
IF MY PHONE IS NOT IN SILENT MODE THEN WHY IT IS NOT VIBRATING.
sir kindly check the settings
Go to profiles
select your active profile ,
go to personalise,
scroll down ,
check whether the vibrating alert is set to on,
if off ,select and switch it on ,
click back , save changes , and activate your current profile ,
and if still the problem persist u can mail me at cellphonez99@gmail.com..... hopefully this will surely slove your problem
Dec 03, 2010 | Nokia 3110 Cellular Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
Cannot get the Nokia 2760 to shut off ring and just vibrate. Any suggestions
hi, you need to go to the phones menu then goto settings now under settings look for profile select this then go down to silent and then press the options button it should then ask you if you want to activate or edit choose edit then scroll down and choose what you want on such as ring tone off and vibrate on, once you have changed the settings ok it then all you need to do is go back into profiles and select silent then activate this profile this will then change to the settings you have chosen and do the same to go back enter profile then choose general and this will then put your ringtones back on.
May 14, 2010 | Nokia 2760 Cellular Phone
******** function on Nokia 2610
Go to PROFILES and the one that is highlighted select CUSTOMIZE and you should see your RING options there/. Make sure you SAVE before you exit out.
Dec 15, 2008 | Nokia 2610 Cellular Phone
Nokia 6300
hi, have you tried enter setup then profile then select general this should then set your phone back to normal if not then instead of going to general go to silent and change the settings under the silent profile, like turn ringtone on and select ringtone.
Try the first option first as this is quick and easy failing than then just change the settings under the silent profile then you can even change the name from silent to general then you can change one of the other profiles to silent so try it then get back to me if you need further assistance ok
Apr 25, 2008 | Nokia 6300 Cellular Phone
Changing the ringtone
actually jkhnetx i can help you address those problems
if you want it to ring and vibrate at the same time, do the following:
1. open phone, and push the side key under the memory card slot.
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options. you can also edit the MESSAGE and PHONE SOUNDS options.
cheers!
Oct 11, 2007 | Samsung SYNC SGH-A707 Cellular Phone
LG Shine KE970 Cellular Phone Logo
127 people viewed this question
Top LG Cell Phones Experts
kenneth njonjo
Vorked Entertainment...
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
