1. Read the following data in two different files File A: aaaaaaaadddddddd bbbbbbbbeeeeeeee ccccccccffffffff File B: 11111111 22222222 33333333 By using the above files print the following output or write it in the Other file as follows aaaaaaaa11111111dddddddd bbbbbbbb22222222eeeeeeee cccccccc33333333ffffffffffff on c language
Krenn
  • 59 Answers
SOURCE: cmd screen print help
hmm... you could try the "&" option...
Dir & Dir >>dir.txt
you might also try the clip.exe program, described here:
http://blogs.techrepublic.com.com/window-on-windows/?p=521
although i haven't tested the clip exe, so it might just leave you with the same problem...
Posted on Mar 28, 2008
  • 477 Answers
SOURCE: how to uninstal avg 7.5 ?
try to download the avg8 from here and install it. then if you want to uninstall run uninstaller from controlpanel for avg8.
the avg8 should be able to remove avg7
Posted on Feb 24, 2009
  • 8 Answers
SOURCE: missing hal.dll. file
Try this support link from Microsoft this help me to solve similar problems
http://support.microsoft.com/kb/314477
Posted on Mar 17, 2009
  • 109 Answers
SOURCE: FILE DAMAGED
just insert the original xp software that fix your damage file
Posted on Aug 25, 2009
SOURCE: Windows wont start up.
Yes you need winxp or recovery disk.
Then boot your computer with that disk.
For that put that disk in cd rom.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot option then set first boot device as your cd or dvd rom.
Then save settings then it boot with that winxp disk.
Then follow the procedure you get message when it find your previos version of windows then press "r"
then it repair your winxp.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 02, 2009
Testimonial: "Thankyou for your fast response. I will try the CD. Kate"
Accidentally deleted files
Delete your needed files off from your USB hard drive without backups left? What a pity! But, don't worry! In your case, without drive data backups, you also can try to take them all back with data recovery software.
Just follow this video to get your needed stuffs back step by step:
https://www.youtube.com/watch?v=Lqb0uxpq2mQ
Just back up everything needed well in the future.
Jul 09, 2013 | Memorex Mega TravelDrive 4 GB USB Hard...
How do i fix windows delayed write failed. failed to save all the components for the file \System32\00007e87. The file is corrupted or unreadable.
Description:
Application popup: Windows - Delayed Write Failed : Windows was unable to save all the data for the file [name_of_the_file_you_want_to_save].
The data has been lost. This error may be caused by a failure of your computer hardware or network connection. Please try to save this file elsewhere.
Cause:
This problem occurs when the data redirector of a System flushes the contents of the file, and writes to a file handle with read-only access instead of to a file handle with write access.
When the redirector received an opportunistic lock break to none, it purged the cache for the file, but did not uninitialize the cache for the file.
More Information:
The redirector also needed to purge and uninitialize when the set end of file occurs because the opportunistic lock break is asynchronous. Because it did not uninitialize the cache for the file, it wrote to the incorrect file handle.
Remediation:
Warning: Serious problems might occur if you configure the registry incorrectly by using the Registry Editor. Microsoft recommends that you create a backup of your current registry before making changes.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then press ENTER.
3. In Registry Editor, locate the following subkey in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet \Services\LanmanServer\Parameters
4. In the right pane, click EnableOplocks, and then press ENTER.
5. In the Value data box, type 0, and then press ENTER.
6. Quit Registry Editor.
This problem occurs when the redirector flushes the contents of the file, and writes to a file handle with read-only access instead of to a file handle with write access. When the redirector received an opportunistic lock break to none, it purged the cache for the file, but did not uninitialize the cache for the file. The redirector also needed to purge and uninitialize when the set end of file occurs because the opportunistic lock break is asynchronous. Because it did not uninitialize the cache for the file, it wrote to the incorrect file handle.Back to the top RESOLUTION Service pack information
To resolve this problem, obtain the latest service pack for Microsoft Windows XP. For additional information, click the following article number to view the article in the Microsoft Knowledge Base:
322389 How to obtain the latest Windows XP service pack Back to the top Hotfix information
A supported hotfix is available from Microsoft. However, this hotfix is intended to correct only the problem that is described in this article. Apply this hotfix only to systems that are experiencing this specific problem. This hotfix might receive additional testing. Therefore, if you are not severely affected by this problem, we recommend that you wait for the next software update that contains this hotfix.If the hotfix is available for download, there is a "Hotfix download available" section at the top of this Knowledge Base article. If this section does not appear, contact Microsoft Customer Service and Support to obtain the hotfix.Note If additional issues occur or if any troubleshooting is required, you might have to create a separate service request. The usual support costs will apply to additional support questions and issues that do not qualify for this specific hotfix. For a complete list of Microsoft Customer Service and Support telephone numbers or to create a separate service request, visit the following Microsoft Web site:http://support.microsoft.com/contactus/?ws=support
Note The "Hotfix download available" form displays the languages for which the hotfix is available. If you do not see your language, it is because a hotfix is not available for that language. The English version of this fix has the file attributes (or later) that are listed in the following table. The dates and times for these files are listed in coordinated universal time (UTC). When you view the file information, it is converted to local time. To find the difference between UTC and local time, use the Time Zone tab in the Date and Time tool in Control Panel.Windows XP SP1, Windows XP Tablet PC Edition
Date Time Version Size File name
30-Jan-2003 21:41 5.1.2600.1164 400,896 Mrxsmb.sys
30-Jan-2003 21:41 5.1.2600.1164 154,880 Rdbss.sys
Windows XP 64-Bit Edition
30-Jan-2003 21:41 5.1.2600.1164 1,259,392 Mrxsmb.sys
30-Jan-2003 21:41 5.1.2600.1164 489,216 Rdbss.sys
Back to the top
WORKAROUND
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 How to back up and restore the registry in Windows
To work around this problem, disable opportunistic locking on the file server:
Back to the top
STATUS
Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article. This problem was first corrected in Microsoft Windows XP Service Pack 2.
Back to the top
MORE INFORMATION
For additional information about opportunistic locking, click the following article number to view the article in the Microsoft Knowledge Base:
296264 Configuring Opportunistic Locking in Windows 2000
A trace of this problem shows that the file is opened at least two times, and shows the system improperly writing to the read-only file handle. A trace that shows this problem is similar to the following:
96 CLIENT SMB: C NT create & X, File = \newshare.xls
SMB: Desired Access = 0x00020089
(Read Data,Read EA,Read Attributes)
97 SERVER SMB: R NT create & X, FID = 0x5
SMB: Oplock Level = Batch
<content removed that displays the client program reading and locking the file, but the file is not closed>
450 CLIENT SMB: C NT create &amp; X, File = \newshare.xls
SMB: Desired Access = 0x0002019F
(Read/Write Data, Read/Write EA, Read/Write Attributes)
451 SERVER SMB: R NT create &amp; X, FID = 0xc007
SMB: Oplock Level = NONE
<content removed that displays the client program reading, locking, writing and flushing data on this file handle>
585 CLIENT SMB: C write &amp; X, FID = 0x5, Write 0xc00 at 0x00005000
PID = 0xFEFF TID = 0x1002 MID = 0x4400 UID = 0x0801
586 SERVER SMB: R write &amp; X - NT error, System, Error, Code = (34) STATUS_ACCESS_DENIED
Note The process identifier (PID) of 0xFEFF in frame 585 represents the client system process that is using the read-only file handle. It does not show the client program writing the data to disk.
Back to the top
Oct 31, 2011 | Dell Inspiron 1000 Notebook
Accidentally a video data file replaced in the same name in same drive. how can i recover my data at this condition?
Instructions:
Things You'll Need: Glary Utilities 1. Download Glary Utilities by following the link provided in the "Resources" section below. Click "Download Now" and then "Save File" when asked if you would like to save the file. 2. Double click the newly downloaded file. It will appear in either a "Downloads" pop-up window or as an icon on the desktop. Click "OK" and then click "Run" when asked if you would like to run the program. 3. Click "Next" when the installation wizard launches and then follow the remaining prompts to complete the installation. 4. Launch Glary Utilities and click the "Modules" tab. 5. Select "Privacy & Security" and then "Uninstall." Select the location on the hard drive where the overwritten file would be and click "Search." Glary Utilities will now scan the hard drive for files that have been removed and overwritten. 6. Select the overwritten file you want to recover once the scan is complete. Click "Restore." You will be prompted with a message stating a file already exists there. This is the updated file. Create a different name for the file that you want to recover and click "OK." The overwritten file will now be recovered.
Read more: How to Recover Overwritten Files in Windows XP ' eHow.com http://www.ehow.com/how_5164783_recover-overwritten-files-windows-xp.html#ixzz1Ct1y0y7R
Feb 03, 2011 | Computers & Internet
While i am coping file in computer it display a message file intigrity violated and file are not being copied
Each block of data written onto the disk is immediately followed by a few "extra" bytes, namely the CRC ("Cyclic Redundancy Check") bytes. The value of the CRC depends on the data just written.
When reading your data from the disk, the CRC also is read.
A new CRC is calculated from the just-read data.
If the "new" CRC does *NOT* match the "old" CRC, then you have a "file integrity" problem -- either your data was not written correctly, or your data could not be read correctly.
It's a sign that your disk-drive is "dying".
Make a copy of all the other files, and save your pennies, to pay for a new disk-drive.
Oct 07, 2010 | Computers & Internet
Whst is the difference between .mdf,.ldf & .sdf?
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Dec 03, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
Reg. MS excell file
try renaming the file and put .xls
hope this helps.
Feb 14, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
