Question about Health & Beauty
I have 27 age, I am a short man. My problem is that how can increase my body length and what is the solution ?
  • 490 Answers
There is no non-surgical way to become taller. You must become taller in your spirit. When you become content with your height, others will also be content. A quality man is not remembered for his height, but by his deeds. farmerbear at FixYa.com
Posted on Oct 07, 2010
Hi I have a 507 machine and I have a problem getting the material to feed through What can I do about this?
Increase the stitch length (perhaps the stitch length is set too short so the fabric does not move).
Check that the feed dogs have not been dropped, as for darning.
Apr 04, 2017 | Sewing Machines
What are the benefits of using Apexatropin?
There are many benefits of using Apexatropin. Some of the benefits are:-
• Apexatropin grows P e n i s effectively increasing blood flow to the P e n i s.
• It increases the firmness of the P e n i s giving harder erections.
• It increases a man's stamina in bed making him last longer.
• It aims to revitalize a man's whole body and therefore helps in providing a healthy L i b i d o.
• It boosts testosterone levels in the body and all the benefits that come with it such as high S e x u a l stamina and vitality.
• Apart from increases P e n i l e size, it also increases its volume.
• It is a 100% natural and therefore safe to use.
You can to go the link below to to know details about Apexatropin:
Apexatropin Review Does it Really Work Read Here Health Bulletin
Dec 29, 2016 | The Computers & Internet
X(2x+3)=90
Solve the resulting quadratic equation
2X^2+3X-90=0
Discriminant: (3)^2-4(2)(-90)=729=(27)^2
Two roots
X_1=(1/4)*(-3+27)=6
X-2=(1/4)*(-3-27) =-(15/2), negative
Since the width must be positive, reject the negative root and keep X_1=6
Width =6
Length=2(6)+3=15
Check 6*(15)=90. Checks OK
Apr 23, 2014 | Office Equipment & Supplies
How do I set up the GNC ProTrack GF-0008 Digital Pedometer Plus Body Fat Monitor:
I just won one from GNC and not sur if it is working properly, because screening is flashing in some type of error mode. removing battery was only way to reset.
1. First normal screen is the time display. (only shows 3 numbers.)
2. Press "set" then up/down for correct time.
3. after setting time, press up/down for 12h/24h format
4. Press "mode" & NO 1 flashes, showing Wt 50 Kilo & Man
5. Press "Start" and place one thumb on each end of unit to auto-read body fat.
6. Set weight in Kilos (not sure how to convert unit to lbs, before setting, so maybe use online converter.
7. Set ht, age, man/woman, stride, using up/down arrows.
Follow process for users 2-5,
Mar 07, 2013 | Generic GNC ProTrack GF-0008 Digital...
Is Pilates a good type of exercise for men or is it just suitable for women?
Pilates Yoga Exercise is suitable for both man or woman. it's
beneficial for body breathes with its movement postures.
Include Hot Pilates Yoga in your daily routine & get several benefits for your body. Likes
  1. Increases Joint Flexibility.
  2. Create Peace.
  3. Raises Consciousness.
  4. Focuses Your Mind.
  5. Reduce Anxiety.
  6. Can Help Reduce Asthma.
  7. Reduce Insomnia.
  8. Improves Cardiovascular Function.
  9. Improve Circulation.
  10. Reduce Headaches.
  11. Reduce High Blood Pressure.
  12. Relieves Back Pains.
Sep 10, 2012 | Exercise & Fitness
What is 'stacking'?
This isthe amount of increase in weight as the bow is drawn. It occurs in all bows,but can be intensified in three ways. First, the bow may be too short for thedraw length. A longer bow could help this problem. Second, the ratio offiberglass weight or thickness should also be increased. Third, the moreradical the limb design the more the stack will increase. This means that at agiven limb length the bow weight, a more pronounced recurve design, will stackmore at full draw. The use of multiple tapers in a limb can also causestacking.
Jul 09, 2012 | Archery
How to build height without medicines suggest only exercise
1. VERTICAL HANGING:
This is a simple but an extremely effective stretching exercise which you can do at your home. All you need to have is a solid bar strong enough to hold an individual, fixed at least 7 feet above the ground such that the distance between your feet and the floor is atleast 4-6 inches. Hold your arms neither closer nor wider and start hanging. Hold as long as you can, and as you begin to tire, slowly swing back and forth and try to touch the ground with your feet. This will flex your spine and elongate it, so that you can add few inches to your height
Make sure that you flex your spine while stretching, and not merely twisting your wrists
Perform the Workout 3 times a week for optimal results
2. COBRA STRETCH:
This is basically a Yoga exercise intended to stretch your spine and make it supple and flexible, so that the cartilage between your vertebrae grows thereby increasing your vertical height
Lie on the floor face down with palms on the floor under your shoulders. Begin to arch your spine up leading with your chin. Arch as far back as possible. Do 3-4 repetitions with each repetition lasting between 5-30 seconds
3. PILATES ROLL OVER:
This is an excellent workout to stretch your spine and lengthen your upper body. Apart from your spine, it also stretches and lenghthens the vertebrae of your neck.
Lie on your back with your arms along your sides, palms down. With your legs together, extend them straight up toward the ceiling and bend them backwards so that they touch the floor. It may not be possible to touch the floor at first, but you can do this by practice. The more your stretch, the more your spine lenghthens
4. FORWARD SPINE STRETCH:
Sit up tall on a mat. Your legs are extended about shoulder width apart, and your feet are flexed. Reach the top of your head but let your shoulders stay relaxed. Inhale and extend your arms out in front of you and slowly bend forward and try to touch the tips of your toes. If you are able to touch your toetips, stretch even forward so that your spine is flexed to the maximum extent.
Do 3-4 repetitions and hold each stretch for 10-15 seconds
5. ANKLE WEIGHTS: This exercise is solely intended to increase the length of your lower body, by stretching the cartilate between your knees. Prolonged stretching will elongate the cartilage and increase its mass, which in turn will increase the length your lower body
Sit on a high chair and use a Ankle weight fastener to add weights to your ankle. Start with small weights initially and gradually increase as you go on. Allow your legs to stretch down with the pressure of the weights. Once completed, remove the weights and relax your legs by kicking your legs gently for 5-10 times, and then vigorously for 5-10 times. This will flex your knee cartilate to enable it to grow in length
Apr 13, 2012 | Health & Beauty
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Snowboard length fit
"Length is one of the most important characteristics of a Snowboard. The length of a Snowboard is measured from the tip of the nose to the end of the tail. The length is usually measured in centimeters and often abbreviated to just the last two digits. Board length varies from 100cm to 180cm. To find the appropriate length for you, start by comparing the board length to your height. Although there are no dead set Rules in Selecting Board Length, the following are several guidelines to get you started. When holding the board on its end: * Short board should reach somewhere between your collar bones and chin. Shorter boards are easier to maneuver, great to be trained on, and often preferred by riders who do a lot of Snowboarding Tricks, park and Pipe Riding. * Medium length should come up between your chin and eyebrows. This length is preferred by all around intermediate to advanced riders who ride a variety of terrain, including parks and steeps. * Long boards should go from your forehead to several inches over the top of your head. Long boards are used for high-speed carving, deep powder snow surface, and big mountain terrain. Choosing the suitable board length is not only influenced by your height but also by your weight. Keep in mind that a Snowboard acts like a leaf spring - it has no clue how tall the person standing on it is. However, it does know your weight. Based on your weight or body structure, the following will help you choose the Right Length of Snowboard: * Lighter people should have shorter, more flexible boards. This is because a lighter person on a longer board commonly has a hard time controlling the board and initiating turns. * For an averagely built person, the board length should reach somewhere between the chin and your nose. * Heavier people should have longer, less flexible boards. A short board isn't advisable for heavy riders because the board often have a tendency to ""wash out"" or perform poorly, especially at higher speeds. * Freestyle riding is often done with a shorter board to allow better maneuverability. * Freeriding, deep snow, and racing boards will be longer in size. * For riders who are into Backcountry Snowboarding, go longer for stability. You may also consider your aggressive or timid style. If you're the type of boarder who really attacks the hill, you'll want to increase the length of your Snowboard up to five centimeters from the average size. Then again, if your riding style is naturally slower in character, go down five centimeters. Still, keep in mind that one Snowboard doesn't do it all."
Dec 01, 2008 | All Star Forum Star Women's Snowboard
How to set page length in computer for dot matrix printer model wep 800DX
to set up page length in inches
?? chr(27)+chr(67)+chr(0)+chr(12) - for 12" page length
to set up page length by lines
?? chr(27)+chr(67)+chr(50) - for 50 lines / page
Jul 20, 2008 | Epson LQ-2180 Matrix Printer
Health & Beauty Logo
79 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
