Question about HP DeskJet F380 All-In-One Printer
How do you scan with this printer using windows 7
  • 372 Answers
Try Scanning with Windows fax and scan program
  1. Click the Windows icon (How do you scan with this printer using windows 7 - c01319360.gif ), click All Programs , and then click Windows Fax and Scan .
  2. Click New Scan .
  3. Make any desired setting changes, and then click Scan .
  4. (from hp.com):
Posted on Sep 29, 2010
Can I use my Epson RX630 printer/scanner with windows 7 ?
Yes, the RX630 can be used with Windows 7 (x32 or x64). See http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=stylusrx630&SelOS=Y for the available software. This printer is very similar to the RX620; thus those drivers/utilities may be useful. https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads&platform=OSF_W_7-64 . Use the Control Panel Add a Printer feature if the printer is not identified by the New Hardware Wizard with the USB connection. (First make sure that you have the printer connected directly to the computer's USB ports and that it is in a working port.) If Windows 7 doesn't automatically find the driver for the scanner of the all-in-one, load the appropriate driver for Vista. However, the buttons on the printer may not work to launch the scan to computer applications. If that happens, launch your scans from the computer. Windows 7 comes with Windows Fax and Scan to handle basic scans.
I hope this helps.
(The Epson Event Manager is needed to launch the scans from the all-in-one. It's not listed separately at the first link to Windows drivers/software for the printer given above.)
Jan 06, 2016 | Epson Office Equipment & Supplies
How do I scan from a wireless printer, Canon , to a HP computer, windows 7
Use the supplied Canon Software. Select scan and follow instructions. Alternately scan to an SD card and when done insert and read from PC.
Jul 31, 2014 | Canon PIXMA MG5520 Wireless Color...
X7350 lexmark to windows 7
you will have to remove the printer software and then reinstall it again some of the driver flies has gone when you clean the system from virus
Apr 17, 2012 | Lexmark X7350 All-In-One Printer
I cannot sacn from hp 3030 with win 7 64 bits
The only way you will be able to scan to your Windows 7 unit is to use the Windows Scanning feature. HP does not make or support 64 bit scanning software for Windows 7
Jan 10, 2011 | HP LaserJet 3050 All-In-One Printer
What is the process to save a document or picture scanned with my HP Deskjet F4280? I am using Microsoft Windows 7. I am unable to install any HP software for this printer/scanner while using Windows 7.
There is no need to install any software for scanning from Windows 7 computer.
It's very easy
On computer click "Start" (windows icon)
click "All Programs"
click "Windows Fax and Scan"
click "Scan" and complete the scan as per on-screen instructions there
Make sure printer is turned on and connected to computer through usb cable properly.
Dec 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
HP Color Laser Jet printer CM1312nfi: scanner no longer working; when I try to scan, receive error on printer:scanning error, cannot connect. Printer is networked. This error occures only on a networked...
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Jul 22, 2010 | HP LaserJet CM1312 All-In-One Printer
Cannot connect 1350 printer with windows 7
The printer PSC 1350 is not compatible with Windows 7.
We can directly plug and play it to use the Printing Part.
And in order to scan, only way to do is through Windows Application.
There are different softwares and ways to scan, use as per your choice.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01884960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
May 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
How to use a scanner?
What OS do you have? If you have a Windows XP or 2000, download and install the full-featured software and use the HP software to scan.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=306895&
If you have Vista and Win 7, HP doesn't have a full-software driver package. You will be using the drivers built into the OS.
For Vista, you can scan using the Windows Photo Gallery (File, Import from Scanner) or Paint (File, From Scanner or Camera) and with some versions Windows Fax and Scan (New Scan, File, Scan).
If you have Windows 7, Paint and Windows Fax and Scan will let you access the images/documents on the scanner.
In all cases, a good cable and ports will make scanning much less frustrating.
I hope this helps.
(alternatively, you could get third party software for Vista or 7. PaperPort is one example)
Mar 27, 2010 | HP PSC 1350v All-In-One InkJet Printer
Epson rx 425 is not compatible with wind 7 cannot add printer to pc
You should be able to install it using built-in drivers of Windows 7, using Windows 7 'Add a printer wizard'
If you have tried this and it does not work then you should refer to Epson, as they claim this is the correct procedure on their website.
You will need to download the Windows Vista version of 'Epson Scan' to enable scanning with your machine, however.
Mar 03, 2010 | Epson Stylus RX425 Multifunction...
Own a lexmark X7350 printer. Have Windows 7 OS. Downloaded the Vista driver for printer. Cannot scan a document. have to use Lexmark Photo Editor and scan as a black and white photo. This info was...
Upgrading to Windows 7
Lexmark X7350 support
Summary Use Vista Driver in Windows 7
Detail Driver Support
For many of our products, the Vista driver will work in the Windows 7 environment.
Driver Availability
The links below list products which have Windows 7 support.
Windows 7 Home Office and SMB Products (Inkjet and All-In-One)
Windows 7 Business Products (Laser)
Driver Delivery
Windows 7 Compatible Drivers are available from the following sources:
Download from support.lexmark.com
Recently released printers include Microsoft Windows 7 drivers on the Software and Documentation CD provided in the box with the printer
Many printer models have drivers included with the Windows Operating System or available through Windows Live Update
Feb 06, 2010 | Lexmark X7350 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
160 people viewed this question
Seeker5211
Seeker5211
