Question about Acer Computers & Internet
From what I have read, my inverter board has gone haywire in my acer flatscreen monitor. the screen lights for a second or two then goes very dark with a ghost of the computer's desktop image barely able to be seen with a flashlight (lights stays green on monitor). I am by no way a computer repair person, but i do like to try to atleast diagnose my own computer problems. This seems to be the problem this morning. is there an easy fix or do I just buy another monitor and call it a day?
  • 1,031 Answers
You can change the inverver PCB or check the cable running from board to ya screen for any possible loose lighteen and check for any effect b4 changing the inverter board
Posted on May 24, 2008
POLAROID 40 Flatscreen
If there is a problem with the backlight inverter. the powersupply it goes into the security mode after start after a few seconds if there is something wrong .example image
Nov 20, 2015 | Polaroid Televison & Video
On my Acer AL1916W monitor the screen comes on for a few seconds then goes off but the power light is still green.
That is often an inverter failure. Try turning off the room light, and point a flashlight sticking to the dark screen. If you can see a very faint picture, then the inverter has failed.
Before replacing the inverter, the PSU must also be tested. If the PSU does not supply power to inverter, then the PSU and not the inverter is the part to be tested.
If the screen is not dark, but there is backlight and no picture, then the problem is not the inverter. In that case check the source and the connection cable. If the cable is OK, then it is usually the main controller board inside the monitor. Once again the part must be tested.
Mar 10, 2011 | Acer AL1916W 19" LCD Monitor
When switched on screen is live for about 1 second then goes black
My flat screen monitor does not light up. Could it be a burned bulb>
Oct 18, 2010 | Acer V193w LCD Monitor
What is the screen resolution for acer al1716 monitor
Hold the power button down for at least 10 seconds till the light goes out, then turn it on and the problem is gone.
May 16, 2010 | Acer AL1716 17" LCD Monitor
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Comes on for second with picture and goes black. turn off and back on will do same thing.
Sounds like it is probably the inverter board. You can find one on eBay, they are usually the problem, not the backlight or screen. Simple change usually and you are good to go. Very inexpensive too, search ebay for inverter board acer P241W, or I have gone to too.
Dec 17, 2009 | Acer P241W 24 inch Monitor
ACER AL 2017 goes dark after half second of image.
I had the same problem with the same monitor. You could see the image, but extremely faintly. In my case, the problem ended up being the inverter board (Delta DAC-12M033), which I found refurbished on Ebay for $45.00. Takes about 30 minutes and about 15 screws to replace, if you are handy in that department. Just my $0.02 worth. Hope that helps!
Oct 02, 2009 | Acer AL2017 20" LCD Monitor
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Problem with monitor
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
Computers & Internet Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
