Question about Intel Motherboard
My mother board require -5v wire for support of 2gb ram otherwise it get reset .and that supply is unavailable....
  • 699 Answers
The voltage available on your motherboard should be of no concerns in the choice of memory: ou have to select a compatible memory of the correct specifications and speed: for example you have DDR, DDR2 and DDR3 memory stick as well as SDRAM and SODIM ones all of whcih are not compatible. A motherboar requiring say a DDR-400 may not operate very well with even a DDR-333 ... unless you lower the motherboard clock speed ...
Hope the information helps.
Posted on Sep 28, 2010
Power supply to mother board connection manual for 600watt diablotek model number (psle600)
if it's a PC psu
The connectors voltage are indicated by colors
yellow is 12V
red is 5V
orange is 3.3V
black is 0V(GND)
green is PSon
purple is 5Vsb
blue is -12V
white is -5V(optional)
gray is PWRGOOD/PWROK
Nov 30, 2012 | Diablotek Computers & Internet
Does asus p5n73 am mother board support asus ati radeon HD 6450 graphic card? my smps is 450 watt also let me know which graphic card support my mother board
your power supply is at the edge, so i'd suggest going for 650W power supply. your mainboard will support the graphics card but as i said - you need better PSU
Mar 13, 2012 | ASUS HD 6450 DDR3 PCIE Native HDMI SILENT...
Does not boot up, power supply is definitely working. Onboard led is one, but ram slot led is not. \ What's wrong?
Hi, Please do one thing, make sure that all the wires are properly plugged into the mother-board. As the light on the mother-board is on remove the ram(memory) from the board. If you have more than one ram(memory stick) installed then try changing their slots first and then if it doesn't work, remove them one by one and and change their slots. It should take care of the issue. Otherwise try changing with a new ram, if it also doesn't wok then you have to check with the local technician as the problem is with the mother-board. Hope it Helps. Regards. Anand Sachan
Nov 07, 2010 | DFI LANPARTY DK P35-T2RS LGA 775 Intel P35...
PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard: RAM IS NOT WORKING. SUPPORTING RAM REQUIRED, CAN Y...
*********** supports DDR1 type Ram, you can easily get it from the market. Just ask the retailer to give you the DDR1 Ram, they will ask you how much memory of Ram you want. There are 256Mb, 512Mb, 1gb, 2gb, etc.. the more the better and this motherboard supports upto 2 gb, but some newer make of this motherboard miht have been changed.
May 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
865 MOTHER BOARD VOLT OUT PU PIN
Hi Dear, well, you can get 1v dc or 1.5v dc from any pc motherboard but I'll never recommend you to do that. You can use Black and Red wire combination to get 5v dc or Black and Yellow wire combination to get 12v dc from motherboard's power supply. 3 LEDs in series can b use for 5v dc input.
Mar 31, 2009 | Intel D865GBF Motherboard
I need a mother board.HELP
It would probably be cheaper & better in the long run to pick up a Intel Core 2 Duo cpu, motherboard, & RAM combo at a store like newegg.com or Tigerdirect.com than try to replace this old board. You can find a really good combo for around $400. Hope this helps.
Mar 05, 2009 | Intel Motherboard
Power Supply Problem with -5V
Get the original power supply for that mother board, don't save money and don't fool around with the computer like that!!
Dec 18, 2008 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
