Question about Kitchen Ranges
No spark for my echo 660 esp chain saw .has a new plug & pin is in
  • 398 Answers
SOURCE: need to know oil to gas ratio mix for echo 510 evl chain saw
50:1 or of its old 100:1
Posted on Mar 20, 2009
  • 83 Answers
SOURCE: intermittent spark, new spark plug, no start
Remove your flywheel cover then unhook the small wire from the magnito (coil). Tuck this wire out of the way. Reinstall your cover than start the saw. If your spark remains constant you have a short in the kill circuit or something is bent or misaligned between the off switch and the kill wire. If you still get intermittent spark, your magnito is going bad.
Posted on Mar 31, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
lemmingleejn
  • 173 Answers
SOURCE: echo chain saw 16 inch will not start
You need to play about with the timing adjustment.
You can adjust the timing by two different methods.
The first is to adjust the space on the spark plug.
The other is to adjust the gap between the contact, and the coil/magneto.
There ya go, FixedYa !))
Don't forget to rate, thanks.
Posted on Aug 01, 2009
dontbother10
  • 2220 Answers
SOURCE: I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
What is the spark plug gap setting for small ECHO CS3450 chain saw with new autolite plug?
0.020" should work well. Check the quality of the spark--it should be blue and snappy with the new plug. Hope this helps!
Dec 10, 2010 | Echo Garden
I have an echo chain saw mdl CS-346 trying to get a new cap for the spark plug. told i need give a ssn. # only # i see on engine caling is 5EHXS.0334CA.says engine family. do see number 02083563 under mdl...
The parts folks are probably trying to sell you a new ignition module which has the cap built in. Try alternate sources for a replacement cap--auto parts stores, lawn and garden service centers, motorcycle shops, even wrecking/junk yards. Good luck!
Jul 15, 2010 | Echo Garden
Echo chain saw 16 inch will not start
May 09, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Saw runs for 3-4 minutes then dies
check the spark plug
change the seals with new ones
check compression
regards Mihai71
Nov 26, 2008 | Echo 30.1CC Chainsaw With a 14 In.bar and...
John deere chain saw model ev55 (1986)
I don't know where you can get a service manual. You've described the symptoms of a dirty clogged fuel filter down inside the fuel tank at the end of the fuel pickup.
Carl
Nov 02, 2008 | Electrical Supplies
Kitchen Ranges Logo
178 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
