Question about Cameras
When I copy my files from my USB stick to my SD memory card and put the memory card into my camera to print the pictures, or if I want to review the pictures on my camera, it says "UNSUPPORTED FILE FORMAT". But I have checked and they are JPEG, so I don't understad why it's saying that.
    Brigadier General:
  • 11,967 Answers
Once you use a computer to write to a memory card, it no longer works properly in a camera because of the different operating system. The only way for the card to work again is to format it in the camera. This erases and optimizes it for the camera.
Posted on Sep 28, 2010
Why is my nikon coolpix L26 not uploading my pictures
First, use the review function to make sure your camera actually took the pictures. Assuming it did, I would remove the SD memory card from the camera and use a card reader to transfer the pictures to your computer. If your computer does not have an SD memory reader, many USB readers are available for under $20. They are USB devices and once they are attached to your computer and you insert the SD card, the computer will act as if the SD card is another external hard drive. You will be able to transfer your photo files from the SC card to a file on your hard drive via copy and paste or drag and drop. Although you can erase your card when you are done by deleting the files, it is better to put the card back in your camera and use the format function found in you camera's menus.
Jun 19, 2014 | Nikon Coolpix L26 Compact
Can I import camera pics to a Dobly Home Theater laptop, by Acer?
First a nitpick: your memory card is Memory Stick Pro Duo, it's not an SD card. Secure Digital is one specific type of memory card, distinct from xD, CF, Memory Sticks, and other memory card types.
Okay, not that I've got that off my chest, yes you can import pics to your laptop. Just connect a card reader to the USB port and then put your Memory Stick into the reader. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Card readers should be available at just about any department, electronics, or office-supply store. One important point to remember is to make sure you get a card reader that can read Memory Stick Pro Duos. If you get, for example, an SD card reader, it won't do you any good.
Jun 11, 2012 | Sony Cybershot DSC-T200 Digital Camera
How to tranfer picture from camera to flash drive
Connect the camera to the computer with the supplied USB cable. the computer will see the camera as an external storage device. You can then copy the photo from the camera to the computer's hard disk and or your flash memory stick.
If you camera has the photos stored on a SD memory card you can remove the SD card and insert it into an USB memory card reader. Then connect the card reader into the USB port of your computer to download the photos from the SD card to the computer's hard disk and or your flash memory stick.
Aug 21, 2011 | Computers & Internet
I need to put my pics that are on my internal memory on my memory stick
Welcome to Fixya,
For you to be able to transfer your pictures form the internal memory to your memory stick, what you just have to do is just follow this steps.
1 - click the menu button and look for the Set up menu
2 - you will see an option for
  • Camera
    • AF mode (Single, monitor) - see below
    • Digital zoom (Off, precision, smart) - see below
    • Function guide (on/off) - describes the shooting mode and a few settings when they are changed
    • Redeye reduction (on/off)
    • AF illuminator (on/off) - turns the AF-assist lamp on and off
    • Auto Review (on/off) - post-shot review
  • Internal memory tool
    • Format
  • Memory Stick tool
    • Format
    • Change/create rec folder - manage folders on the memory card
    • Copy - copies the photos from the internal memory to a MS Duo card
  • Setup 1
    • LCD backlight (Normal, bright)
    • Beep (Shutter only, on, off)
    • Language
    • Initialize - returns settings to defaults
  • Setup 2
    • File number (Series, reset)
    • USB connect (Auto, Mass Storage, PTP, PictBridge)
    • Video out (NTSC, PAL)
    • Clock set
3 - look for the Memory stick tool, then click on the copy-copies the photos from th internal memory to MS Duo card.
From there you can select the pictures you want to transfer to your memory stick.
Hope this steps can help you.
Thank you for using Fixya.
Feb 24, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Cannot copy photos from internal memory to SD Card
try to put the back your sd card in your camera then go to option in your camera and search the copy file to memory / copy pictures...i try this in my camera....it works!!!
if this won't work try to download your camera driver/software...
Hope this can solve your problem
Feb 02, 2009 | Cameras
SD card and camera
Hi nomi_101,
The option that you're lookig for is usually found in the camera's menu. As I remember for Samsung digital camera this option is under "Setup Menu 4" and under that there is the option for "Copy to Card" just highlight that option in your camera select it and select "Yes".
Basically, ALL images, and movie clips and voice recording files (if any) saved in the internal memory are copied to the SD memory card after the "Processing!" message is displayed. Note that when you move images that are stored in the internal memory to the memory card, the next number of file names will created in the card to avoid duplication of the file name. So it won't copy over any picture with the same name/number in your memory card.
Try this out first. Otherwise if you don't see this option I think it's best to check your camera's user manual for the correct procedure, since most camera's have different menu layout and option names. If you don't have the manual you can donwload a copy at http://www.samsungcamera.com/customer/download/cus_down_main.asp just pick the correct camera manual.
Hope this helps!
Peace! :)
Oct 22, 2008 | Samsung Digimax S500 Digital Camera
Cant download pictures usb
Take your sd memory card out of your camera, and put it in your computer. A file with your pictures should appear. Copy thoes pictures into a different fold on you computer. Take you sd memory card out of your computer and plug it back into your camera. Your pictures will be both on your camera and on your computer.
I hope this solution helps. Please rate this solution.
Oct 10, 2008 | Nikon COOLPIX L18 Digital Camera
Copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Jun 22, 2008 | Kodak EasyShare C330 Digital Camera
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
