Pioneer vsx-917-s/-k suddenly says overload and switches off while watching a dvd
  • texasangler Jan 17, 2009
    pioneer vsx-917v suddenly says overload and shuts down
  • barnglo Feb 09, 2009
    same thing.. just says overload. i have all but Surround Back speakers set up.
Pioneer vsx-917-s/-k suddenly says overload and switches off while watching a dvd, listen cd and tuner.
Posted on Jun 26, 2008
Pioneer vsx-d510
Disconnect all the speakers, and then check. Connect the speakers, one by one, and find which one makes it overload. That speaker is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Pioneer Audio/Video Home Theater Remote...
How do i put my pioneer receiver to my cable tv,dvd. vsx-917-v-k
For this purpose I am using headphone output of the TV set. I connect the headphone output to the AUXiliary input of the receiver. All you need is an interconnection cable, one end with 3,5 mm stereo male earphone jack, the other end with a pair of RCA jacks. This output of TV provides an additional output signal to your receiver but volume control behaviour (independent volume control for earphone output etc.) changes for different brands of TV sets.
Jan 04, 2015 | Pioneer Audio Players & Recorders
Overload pioneer vsx 808 rds
if it's shutting down when you increase the volume, this usually indicates a bad speaker.
Jul 03, 2013 | Audio Players & Recorders
Receiver will not switch to tv/dvd , the sound works fine when watching dvd's or video but will not switch back.
can you scroll thru the inputs with the remote,and/or the input knob on the receiver.have you set up your inputs via the on screen menu?
Jul 06, 2010 | Pioneer VSX-815-K Receiver
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
Overloads all the time under 40db.
Hi Glen. The thing with these new units is that they are so fussy when it comes to frequency range on the speakers. The frequency has to be within the range that the amplifier specifies, or you'll have problems. I suggest that you check your manual to see what the required frequency shuold be and take it from there. I have one myself and love Pioneer
Aug 02, 2009 | Pioneer VSX-D509S Receiver
DVDLD stuck on defaualt setting
There is a signal select switch witch if depressed will change the dvd/ld switch back. give it a shot.
Jan 29, 2009 | Pioneer VSX-D411 Receiver
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
1,301 people viewed this question
 Grubhead
Grubhead
