Question about ASUS A7V266-C (A7V266-C W/A) Motherboard
Green pwrLED is not ON even the PSU is plugged in and and main switch turnd on! I already tried another PSU and problem remained the same, so i excluded PSU as one of the reasons of the malfunction. I just bought new case for my PC, and i repacked all the components including mobo. I old case all was working fine... i had completely healthy PC and system. pwrLED was ON first time I put the power cord into PSU on the new case as well, but as I were unable to find proper pins for pwr swich on the front panel i plugged out and plugged in that cord for like few time. After that LED wont light anymore! It happened that it goes light for like second and then go off again. Did i fried something? Pls help.
  • dolke022 Sep 29, 2010
    I manage to fix the problem. It was short circuit because i mounted the mobo directly on the case metal and i believe because mobo is under the voltage it somehow interfered with the metal and disabled it to work properly. All is good now
3 Suggested Answers
  • 317 Answers
SOURCE: K8NGM2 Mother Wont Power Up
I've seen situations similar to yours several times and they've always been a bad CPU.  Since you tried a new video card it's not that, I would suggest a new CPU.  Check on ebay, you can usually find used one's on there.
Posted on Oct 10, 2007
  • 101 Answers
SOURCE: Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
Posted on Jan 02, 2009
Hello My 60PK550 TV started to turn itself of every 5-10 minutes, I switched it of at the power point and waited, now when it is plugged in and turned on at the power point it immediately tries to turn...
check first the psu unplugging the Y-sus from it if the voltages stay on then you have a Y-sus failure if the psu keeps closing then its most likely the psu itself or your main board
Aug 16, 2014 | LG 60PK550 TV
Green light on my power supply stays lit after unplugging
Usually the light will time out after the capacitor has drained. Your machine is getting a bit old , your PSU may be the problem. If you plug it in and push the on/off button and it blinks, fans spin and shuts down, it's most likely the PSU. Look for a in-line fuse on the Motherboard, if blown, replace. Look at the motherboard closely for damaged components, capacitors, etc.
Jan 27, 2013 | HP Pavilion A820n (PP165AA) PC Desktop
Amber flashing light GX620
LOL... If you haven't already fried your motherboard by using your modified PSU (And that's a big IF), then you need to buy a new PSU with similar specs and connection plugs (ie. a 24pin main) as the original PSU that came with the PC.
May 31, 2012 | Dell Computers & Internet
First of all, I have a Gateway Model FX7026 desktop computer. My daughter was using it when suddenly the monitor screen becomes black. She tried to turn the computer on again but nothings happen. I open...
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Mar 31, 2011 | Gateway FX7026 PC Desktop
Hi, what could be the problem of my psu, when i try to connect everything to the motherboard, it doesn't turn my cpu on, but the light on the psu switch is lit, i already tried direct switching via the...
You should try another power supply or just use a power supply tester on it. The tester I only like $10. Most likely the motherboard itself is bad.
Mar 01, 2011 | Computers & Internet
Hi there. I have issue with this mobo regarded to pwrLED which is not ON even with the PSU plugged in. Actually what is happening is that as I turn ON the PSU main switch sometimes i get light from the...
In my experience you may need to replace the case but if you feel up to the challenge you can clean the contact headers on the MOBO for the PW LED and try reseting the CMOS for the bios.
Mar 20, 2017 | ASUS A7V266-C (A7V266-C W/A) Motherboard
Im using a emachines T3646 computer,only pwrled and 1syst fan wrk
Yes. Got RAM? The heatsink fan? How about a video card, and all the 12V (4 to 6 pin) connectors? All plugged in suitably?
May 02, 2010 | eMachines T3646 Refurbished AMD Desktop...
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns;
Feb 19, 2010 | Computers & Internet
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
ASUS A7V266-C (A7V266-C W/A) Motherboard Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
