Question about Sanyo Cameras
It fell into a sand at home and then the lens or that round silver part that comes in and out got stucked.
  • Sanyo Master
  • 17,130 Answers
If the set is not working then it can be damaged with possible sand within. So before you can use the camera it is important to have it cleaned out properly so that ir repairable damage is not done.
Posted on Sep 28, 2010
JZ300 Autofocus not working
Beyond sand getting in, the lens may have been damaged from the impact if it fell on the lens while extended. It may need to be serviced by a technician.
Apr 13, 2014 | FUJIFILM FinePix JZ300 Digital Camera
Lens stuck in the out postion
Did you try taking out the batteries out for a few hours to reset the camera? Did you eliminate the possibility that the batteries can be the cause of your problem?
Dec 26, 2007 | Pentax Optio M20 Digital Camera
Canon power shot sd 750 fell on the floor and is the lens are stuck open and keeps giving me a error for lens. the lens part fell so the lens now are uneven. is there any way i can fix this?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 11, 2011 | Cameras
My camera fell in the sand I don't know if the sand got stuck in it & I don't know if that is what is causing the problem with the lenses not opening
is it notifieing you that there is a lens eror? or does it just not turn on? This type of problem you won't be able to fix yourself, and don't try to either! You will need to contact Kodak and tell them there is a lens eror (don't give details that you shouldn't be giving), hopefully they will be willing to fix it for you or replace with refurb.
Aug 30, 2011 | Kodak EasyShare M1093 IS Digital Camera
Silver lens shroud fell off and now the lens wont extend out and the display is reading"lens error"
As you have dropped your camera due to that lens barrel (focusing ring) is not able extend, Your camera need to be disassembled to get at the focusing ring at Service Center but you can try these solution.
  • What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jun 19, 2011 | Casio Exilim EX-S500 Digital Camera
I went to the beach, and took puctures there. When i got home and tried to use my camera, the lens wouldnt fully expand and the camera says "lens error"
My guess is that the lens has some sand in it. You might just want to open the lens as much as possible and give it a good cleaning with rubbing alcohol on a cotton swab as well as blowing it out with canned air. I know it seams kinda nuts, but if cleaning it doesn't work try to manually push the lens in slightly to free up some stuck sand. Also, you could tap the camera on a hard surface with a small piece of fabric under it to try to knock out some more of the sand.
Hope that helps!
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
Automatic lens cover does not fully open
1. there's a problem inside of the camera especially the gear if the camera fell down or applying excessive force to the lens part. The gear was broken thats why it was not fully open and having weird noise inside.
2 if you went out to the beach or place a lot of dust.possible the sand or dust goes indide of the lens gear and cause of stuck up and not fully open the lens.sometimes becuase of this the gear was damage or broken and you need to bring to service center.
Jun 03, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
FEEL IN THE SAND...
This is a common problem to digital cameras for those who take it to the beach. The problem was that there could be granules of sand in the lens and thus preventing your lens to come out.
What you need to do is to hold you camera on your right hand, with the lens facing downwards. Then turn the camera on as you gently hit it with your left palm. Do this several times until the sand comes out and your lens could retract out again.
Sep 12, 2009 | Casio Exilim EX-Z57 Digital Camera
Today i went to a beach nad my camera fell in the sand. After taken it out when i switch on, the lens does not move at all. It is stucked because of sand and on the screen it says "lens error, restart the...
Sorry to hear that shivamfc. You are an unfortunate Canon user with the unlucky results of digital camera + sand = dead.
To make the camera to work again, you need to be sure to remove the sand that got inside the lens mechanism, unfortunately that is a serious repair and I don't think it can be done by the user.
Perhaps you can contact the manufacturer to see if they have a good solution for you or at least they are kind enough to provide you a rebate is you have to buy a new one.
Some people having trouble with lens mechanism (in cheaper cameras) are "fixing" this issue banging the camera (as this is already unusable) and a few of them are lucky enough to get it working again.
The first idea that comes to my mind is to use compressed air and try to remove any sand particles but I'm not sure that will fix it, also, the CCD can be damaged trying this.
The best recommendation that I can give to you is to contact the manufacturer for solutions.
Sep 06, 2009 | Canon PowerShot SD880 IS Digital Camera
Cameras Logo
97 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
