Question about Compaq Presario M2000 Notebook
Computer boots but no display
The computer boots but there is not display. However, the screen is not dark but has vertical lines with colors.
    Genius:
  • 2,785 Answers
You have to resit your ram
Posted on May 24, 2008
DELL e5510: suddenly whenever I turn on my laptop it will just flash with lines that looks likes threads of clothes? then after a few seconds the screen is just black and full of colored vertical lines (...
Here is a hardware test you can run to test the video and lcd screen. That came with your laptop
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will BEEP ! it is asking you if colored bars are displayed. if the bars look ok then your screen is fine but if during anytime of this test and you see the distortion you described then its the LCD screen or LCD cable
hope that helps
Sep 07, 2013 | Dell Latitude E5510 Notebook PC
Lto much colors vertical lines
hi
if your getting vertical lines in you screen it means you have problem with screen you have to go to services center
this is display issue
Oct 12, 2010 | Acer AL1912 19" LCD Monitor
Ibook display problem
You can reset the pmu this might help to stable the display,this is only used as a last resort and not a possible solution.
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the iBook computer.
Oct 07, 2009 | Apple iBook G4 Mac Notebook
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Occasional colored vertical lines on the screen at startup
base on our experience.... you are looking at a possible screen problem. Is it serious? yes as the screen replacement costs almost half of the total cost of the laptop.
but no harm trying this
1. remove the screws from the LCD bezel, remove the screen
2. detach the cable and reinsert them all both the inverter and the flex cable.
inverter is the circuit usually located at the bottom of the screen and the flex cable is the ribbon that runs from the laptop to the back of the lcd.
reseat them and see if your display improves
Apr 09, 2008 | Sony VAIO PCG-K23 Notebook
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Compaq Presario M2000 Notebook Logo
49 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
