Question about AEG L54600 Front Load Washer
My washing machine has one minute left in the cycle and will not finish and the door will not open.
SOURCE: washing machine not working
I just had the same problem. In my case, a pen cap was stuck in the impeller of the drain pump and prevented it from working. To access the drain pump remove the lower kick panel on the washer by removing (3) Torx drive screws. Make sure you get the water out of your tub before working on the pump or it will spill out on the floor. The pump is front & center. First check the clean-out filter for blockage by turning the big knob on the front of the pump. If that doesn't appear to be the problem, you can take the pump out by removing (1) screw and disconnecting (2) hoses and the electrical connector. The pump itself consists a white housing and a black motor assembly. Remove the motor assembly by removing (3) screws. This is where you will see the impeller and and item that may be preventing it from turning. Besides dealing with the water, the most difficult part of repair is reconnecting the hoses using the hose clamps. Best of luck! RDam
Posted on Jun 29, 2007
  • 1294 Answers
SOURCE: aeg lavamat 538
Your door will not open if there is water still in the machine. Try "spin only". If this fails, get a bucket, remove your outlet tube from the wall drain, put into bucket. Wall plug off first. After all the water is drained try the door, do not force it.
Then check your outlet filter; the water does not go thru for there may be a block in your filter, or tube from the tub to drain area. Or finally in your pump. Dont forget to refix drain pipe in wall in exact position.
And rate me pl.
Posted on Dec 01, 2007
SOURCE: can't open door of lg wd-1018c washing machine
Hi, I don't know if this is much help to you now as it has been a while since you posted your problem. I had the exact same problem and after a lot of swearing and 2 days and no help what so ever from LG I took matters into my own hands.
I took the top off the the machine and removed the small steel plate, you will know what I am talking about after you have done the same.
I had my hubby hold the tub back as far as possible and used a screw driver to release the latch which is at the front of the machine about half way down. You will see a small silver steel knobby looking thing. After the machine was finally opened I unscrewed the screws on the inside of the door and used a flat screw driver to prise the housing apart. Be careful not to drop the glass window as when the housings start coming apart the window is no longer secure.
I found that a small piece of plastic on the handle had perished and broken not allowing the correct function. A phone call to Sunstate spare parts got the new handle to me within a few days at a cost of $20.95.
My only problem now is putting the bloody thing back together. I have been at it for 3 days with no sucess. If you manage to work out how to put yours together please let me know. I hope this has helped and hasnt come too late.
Cherie.
Posted on Nov 20, 2008
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
Why doesn't door unlock after cycle has finished
most have an electric lock, and need to be left for 2-3 minutes before it will unlock. this was put in place to stop people opening the door and getting water everywhere.
Nov 12, 2014 | Zanussi Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Kenmore HE3 2plus wont finish cycle
I'm not saying you don't have a problem. But just to be clear. You do understand that the last minutes on these machines can vary. The machine senses certain conditions in clothing, water discharge, etc. So sometimes the "1 min left" indication can stretch into many minutes. In theory, at least, it's possible your machine just needs to be left alone until it finishes whatever it's doing. However, one would think that any issues not resolved in 10 - 20 min are an indication of a problem. So i guess that's my next question, did you wait long enough? Keep in mind i am not a kenmore expert.
Jan 06, 2013 | Kenmore HE2 Plus Front Load Washer
Door remains locked after wash, no error code or anything.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
Dec 02, 2012 | Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
It does not open
turn the machine off at the mains, after two minutes the door should release from the auto lock, but your pcb (printed circuit board) is knackered start saving.
Oct 15, 2007 | Indesit W 123 Front Load Washer
AEG L54600 Front Load Washer Logo
27 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
