Dear All, my toploader WM Bauknecht WATE 9575 shows the error: PF, acc the DFU the rest water is not pumped out. By tilting the machine and letting the water out via the coin filter I can"reset" it and then it functions for 2 washes; then again the error PF. I do not have a repair manual with circuit diagram, so it is very difficult to check the functioning. Can you help me? I can dismantle the machine (with some tips for the correct sequence..)
blueextc3221
  • 15935 Answers
SOURCE: Need operating manual for Bauknecht washing
Head over tho the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
stradeteox
  • 88 Answers
SOURCE: washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Posted on Jan 07, 2009
  • 880 Answers
SOURCE: I have an 03 error displayed on a Bosch WFK 2801
03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Posted on Dec 01, 2009
barkencoa
  • 3463 Answers
SOURCE: how do i reset zanussi washing machine ZJD12191?
There is ne reset button in the washer to reset, I suspect that when you tipped the washer over, water has got onto the electronics,, more so since you can here it hissing,could prove to be expensive.
Hope this helps.
Posted on Jan 17, 2010
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Malfunction error PF-PM on Brother Innovis 4000D. HELP!!!
try unplugging it and letting it rest for 20 minutes? Sometimes that will reboot it.
Dec 10, 2013 | Brother InnovIs 4000D Computerized Sewing...
WHAT IS THE SYMTOM LE
Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset wate r level within 25 minutes
Oct 19, 2012 | LG WM-1485FHD Front Load Washer
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
LE code
IE: Water level (246) was not reahed in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermister out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
WM-2277HW service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2011 | LG WM-2277HW Front Load Washer
My LG is a few years old, Model WM1832CW and seems to work in all modes except rinse. It just started this morning and sounds like its slipping and grinding and won't pump the water out. any suggestions....
Replace the pump motor. On your model, it can be done without removing the front panel. Open access door at bottom left of front panel. drain water out small hose. remove screw from plastic recess and use putty knife at side of recess to remove plastic recess. remove screw holding pump. pull machine out 2 feet from wall and tilt it back to rest back edge against wall. depress plastic tab in base to release pump. remove hoses and unplug electrical connection to pump. remove 3 screws holding pump motor to pump housing. install new pump motor and re-assemble.
Nov 27, 2010 | LG WM-1832C Front Load Washer
I keep getting an error OE on my LG WM0532HM front load washing machine and it won't spin out the water, just stops after a few minutes
The OE error is "Outlet Error" for the draining the water from the unit.
The unit is having trouble draining the water from the unit and that is why there is an error code.
You need to be sure there is nothing in the pump's filter (located at the bottom left on the front panel) that is restricting the water's flow.
If the pump's filter and housing is clear then it is the pump that has or is going bad.
The pump will fail because a seal will let water into the back side of the motor and case it to lock up.
If you need a part number for the drain pump, let me know.
Apr 24, 2010 | LG WM-0532HW Front Load Washer
Leaking under Washing machine LG serie WM 2277H.What causes and how to fix it? Thanks!
First check all hoses. The hoses inside the unit, sometimes leak and looks like a water pump problem. Does it leak all the time or only when running. If only running , most likely it's the pump. If you and a friend can lift up the front of the unit "tilt" and block it. Use a flash light and look for water around the pump. The pump will be white plastic with 2 hoses running to it. It has to be a hose or pump (90%). I hope this is a start.
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
Apr 19, 2009 | LG WM-1832C Front Load Washer
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
