Can I assign IP address to Dlink DES 1016D switch
bpcs
  • 112 Answers
SOURCE: ip conflict
Click Start, Click Run, type in CMD and hit the enter key, type ipconfig /all after the > sign and then hit the enter key, this will give you the ip address of the computer, the subnet mask and the default gateway, the DHCP server and the DNS server. You can reset the computer's IP address by typing ipconfig /release in the CMD window then typing ipconfig /renew. BPCS
Posted on Dec 30, 2007
  • 192 Answers
SOURCE: won't assign IP address
Try tuning the router off and back on and do the same with the computer.
Posted on Jan 08, 2009
  • 6 Answers
SOURCE: having problem installing my dlink dir615 router
First, is the problem truly that you can't get an IP address from the router or is it that you can't get on the internet. I will touch base with both issues briefly. Many newly placed routers need the MAC address cloned within the router setup to register with the ISP and recieve internet access. If the PC is truely not recieving an IP from the router, make sure DHCP is turned on and set a range of address you wish use. Tip: limit the number of addresses to only what you will actually use. Make sure your computer is set to recieve an IP automatically and you have the proper client, service and protocols running. Basically, If the PC will run directly from the cable modem, then it should run from the router also. If the PC will not obtain an address from the modem directly then your winsocket may be corrupt. Malware will often do this. It is easily repaired and there are many winsock32 repair tools on the net. Just Google "winsock repair" without the quotes and you will find a multitude of software.
Posted on Jan 21, 2009
SOURCE: How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
Posted on May 14, 2009
SOURCE: D-Link DES-1016D make the network failure
Is this a brand new switch? Or did it come from somewhere else? It might have an IP address assigned to it that is interfering with the rest of your network.
Try plugging in a laptop only to the switch and give the laptop a static IP, see if you can access the configuration of the switch.
Posted on Jun 25, 2009
Dlink DES-1016D switch will support CAT6 cable or not
Yes. Cat 6 is for 1000Mbps / 1Gbps, and is backwards compatible. It will simply default to port speed on unit.
Nov 19, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
How to set ip of the router as static ip for my internet cafe
OK, it is NOT the "Router" that has to be set to a Staiv IP, that can ONLY be done, via your service provider, you Router/Modem, is a Slave, device, that gets it's address FROM, a DNS server, via, DHCP, now, IF your ISP assigns you a static IP, then you can do as you want. However, you can still use a dynamic, IP, and do the same, you merely have to have an individual, name, MY_Internet_Cafe.com.. whatever... & register at DNS servers, and that way whenever anyone want to connect to your website, the Name is stored on a DNS server, when the "Request" is issued. "where is so" and so..Then, the search engine, It looks up that INDIVIDUAL ID NAME, , and and regardless of actual "Address", will connect up the requester with the website.. then anyone can connect, and they don't have to know your IP address, they merely type in your "Domain Name" or Website name" and the DNS will do all the rest.
May 04, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
What is the default ip address for dlink 3226?
The Switch's factory default IP address is 10.90.90.90
with a subnet mask of 255.0.0.0 and a default gateway of 0.0.0.0.
Often set up by rs232 connection
See
ftp://files.dlink.com.au/products/DES-3226S/QuickInstallGuide/Generic_QIG_for_Managed_Switches_v1.03.pdf
and
http://support.dlink.com.au/Default.asp
Apr 20, 2010 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Jun 22, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
I want to know the ip config for this brand i have 15 computer
Hold down the rest switch on the back for 30 seconds. Go to start, run, type in cmd and hit enter. When the dos screen comes up type in ipconfig. This should give you the gateway address for the router. I think the standard ip for dlink is 192.168.0.1
May 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
