Question about Magellan eXplorist 500 GPS Receiver
Error Message? "Press ENTER to configue NAND Press ESC to cancel"
I turned my unit on one day to find the following message at start-up "Press ENTER to configue NAND Press ESC to cancel". The unit is locked up and will go to no other screens. I have used this only a half dozen time and returned it for repair already! Can anyone help!!
Lost and AGGRAVATED in Indiana!!!!!!!!!
Thanks
  • 2 more comments
  • Anonymous Jun 03, 2008
    same problem,,,,, Ric in Canada,,,,
  • buckflats Jun 03, 2008
    same problem,,,Ric in Canada,,,,
  • Shersmelley Jun 10, 2008
    I too experienced this same proble yesterday. I contacted Magellan support by email and this is the reply I received:
    " I understand that your unit displays press ENTER to configure NAND. I would
    request you to press Menu, Nav and Power button at the same time. If the
    issue still persist you would have to send in your unit for repair."
    I have not had a chance to try this but will do so as soon as I get home. Has anyone found a solution that works yet. My unit worked great until I upgraded the system. It worked fine that night but the next day I received the above error.
  • puscultra Apr 06, 2009
    Juste update to 2.05 firmware and have this problem... repeat 2 or 3 times.. than nothing work ! NOTHING (even keys combination) ! GPS dead... someone can help ? puscultra @ hotmail com
    Problem Solver:
  • 14 Answers
With you 500 turned off press nav + power; then change the numbers 00 in 95 by using the joystick and and then press the joystick itself; accept what proposed.
after turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. if necessary, in usb file transfer mode, reload the basemap in the directory background maps
Posted on Jun 13, 2008
Press nav and power at the same time-
appears a box where you put 95 with the cursor keys.
and your problem will be solved.
it works with me.
good luck.
Posted on Apr 10, 2009
Error message at start-up reads: "Press ENTER to continue NAND, Press ESC to cancel". Either choice I seclect and the unit shuts-down.
"With you XL turned off press nav + power; then change the numbers in the box from 00 to 95 by using the joystick and then press the joystick itself; (ENTER), accepting what is proposed...
Either FORMAT or SCAN...
After turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. Your system will immediately start to re-set itself.
If necessary, in usb file transfer mode, reload the basemap in the directory background maps..."
My unit is NOW re-booting back to normal!
Posted on Jul 31, 2009
THIS IS THE CORRECT LINK rhamphorinkx team gps site
Posted on Jun 04, 2008
  • 3 Answers
How do i remove or cancel error message h4 on sharp digital ar-153e copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Oct 23, 2015 | Sharp Office Equipment & Supplies
H-400 error on Sharp 165
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
May 29, 2015 | Sharp Office Equipment & Supplies
HOW DO I RESOLVE H - 4 ERROR ON MY AR-5320E SHARP PHOTOCOPYING MACHINE?
OR
Apr 30, 2015 | Sharp Office Equipment & Supplies
Error h4 on sharp at m318 copier
OR
Mar 16, 2015 | Sharp Office Equipment & Supplies
How do i fix a h4-01 error code on my sharp ar m277 copier
OR
Feb 26, 2015 | Sharp Office Equipment & Supplies
HOW DO I FIX ERROR MESSAGE H3-00 ON MY MX M753N
OR
Feb 25, 2015 | Sharp Mx-M753n mx-M753n
My eXplorist XL is locked up
Either FORMAT or SCAN... LET IT RUN!
The only difference is that I had to load my SD card in the unit for it to work during the FORMAT.
Sep 02, 2008 | Magellan eXplorist XL GPS Receiver
Configure NAND on Start up
I finally wound up deleating the base map useing the Maintenance codes, which has now left me with another problem and that How do you rload the basemaps from Mapsend Lite?
Stewart
Mar 16, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
Magellan eXplorist 500 GPS Receiver Logo
1,249 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
