Question about Canon IMAGERUNNER 6570 Copier
In canon 6570 when machine is switch ON error E000004-0106 and sometimes E000004-010 appears , what is the reason?
  • 21 Answers
hi this is srinivas
sir
canon 6570 when machine is switch ON error E000004-0103 and sometimes E000004-010 appears , what is the reason?pls giv me a solution.
thank u
Posted on May 20, 2011
In canon 6570 when machine is switch ON error E000004-0103 and sometimes E000004-010 appears , what is the reason?
Posted on Dec 16, 2010
Serial number location
I have Canon IR 6570 MACHINE. Error E000350-001 is coming. What is the solution
Mar 06, 2014 | Canon For Use in Models Imagrunner 5570 /...
Sir, I have Cannon IR 6570 Error Code E0000013 appear tonight, Please guide me how to solve
You have problem with waste toner assembly. You should remove rear covers, and pwb`s from backs, and then remove waste toner assy.
then check is auger damaged. It is possible to repair auger.
Sep 07, 2011 | Canon IMAGERUNNER 6570 Copier
There is an error in imagerunner 6570 copier E0004-010 it is resolved then Error E00004-0103 occur. What would be the solution. What is the complaint?
press the [shutdown]key. After the machine has been shutdown turn the main power switchon the main units right side
[shutdown]
if the machine still does not operate normally contact your service representative with the error code below
E000025-0001
Sep 06, 2011 | Canon IMAGERUNNER 6570 Copier
Sir i have a canon imagerunner 6570 model machine .it was coming an error code .that was e00004-103 . how to clear the error? pls give me a solution as early aspossible thank u srinivas
goto the service mode by pressing (additional function 28 additional function) .in there got to function then to clear and then clear the error by pressing ok and restart the machine
May 22, 2011 | Canon IMAGERUNNER 6570 Copier
Eror e00014 pada ir 5000, sudah dierror *28* tetapi tetap masih eror. motor pemanas tetap gak jalan gimana yaaaa? tolong dong solusinya...
bos tolong nih, kode error E00004-0010 pada mesin canon ir 6570, gimana solusinya. terimakasih sebelumnya
Mar 17, 2011 | Canon imageRUNNER 5000 Copier
Hi,i have 1 unit ir6570,error code e000001-010,e000004 always appear few times a day.please guide me to solve the problems,i had reset accordingly.from Rahmat ,Penang ,Malaysia.
Press smart head button and hold 2 and 8 then smart head button do this within 4sec the screen will now indicate service. Then hit copier then function then clear then err then ok.Switch off on ps make sure theres nothing wrapped around fixing assy (hot section) as this error code is a thermistor fault
Mar 06, 2011 | Canon IMAGERUNNER 6570 Copier
E0025 error code in machine ir 6570
check the toner bottle.place it properly and lock properly if still error code appears check bttle drive assembly and motor.
Jan 04, 2011 | Canon imageRUNNER 5570 Copier
E000732-0001
just try to reset the error you mst enter to simulation just press *, 2&8 press simultaniously, * , then select copier then select function then select clear then select error the press ok then switch the power off/on, if the trouble appears its means there is a problem in dc controller board just replace it
Nov 22, 2010 | Canon IMAGERUNNER 6570 Copier
CanonPC6RE
I don't know if this addresses your problem, but check this link. If Canon has not already repaired your unit (since September 2006), they may help you out.
May 15, 2008 | Canon IMAGERUNNER 6570 Copier
2,555 people viewed this question
old marine
old marine
