Question about Canon PIXMA MP750 All-In-One InkJet Printer
Wrong cartridge Hi There is a error "wrong cortrisge", when i want to print.
  • 3 more comments
  • melinda_camp Jan 15, 2009
    I have the same problem and so does our office one. We have changed all the cartridge's and it is still showing the error problem.
  • Spania Feb 19, 2009
    I have a Canon Pixma MP750, looking to give it away as I have now replaced it with a cheaper Printer/Scanner. Worked perfectly for 3-4 years, have been using compatible ink cartridges for past 3 years, suddenly it wouldn't print, message wrong cartridge kept coming up, replaced all cartridges, still comes up with same message. Cannot override it, any solutions?
  • rtsquare Feb 20, 2009
    I put FOUR new sets of Cartridges in and get the same error. Why..
    Does the Head need replaced? Do I need to use it as an anchor?
  • tatum_nichol Apr 29, 2009
  • alion May 17, 2009
    My Pixma MP750 sarted doing the same thing. Chaging catridges hasn't helped. I took housing off printer to check for damage, but found nothing. At this point I think the "anchor" idea suggested by previous commentator may be the only solution. I also downloaded the repair manual and found nothing useful there (a waste of $6.00 ).
Posted on May 17, 2009
  • 2,785 Answers
Try with new cartridge
Posted on May 24, 2008
  • 28 Answers
There must be a wrong catridge install a new catridge n then use it
Got "wrong cartridge" error while attempting to print. Removed & reset all ink cartridges, still same error. Removed inks & print head, immediately lost power. Unplugged, waited, put everything...
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Alarm light blinking. wrong cartridge in LCD window.
remove the new cartridge and clean contacts of cartridge and iside printer with Qtips / might have communication problem with cartridge due to dirty contacts..sometimes they get dirty fro spilled ink from jets..then retry
Dec 17, 2007 | Office Equipment & Supplies
Canon mpc 200 error message ''wrong cartridge'', won't print
if you have the old cartridge still check the connection to see if it is the same as you had and check to see if you have an original or compatible cartridge as some wont be recognised.if there is an electrical connection board in it see if you can change it onto the new one
Jul 31, 2009 | Office Equipment & Supplies
Weong cartridge error on my LCD screen--I cleaned
Wrong cartridge error is a problem with the printhead, needs to be replaced. Qy6-0064-000, aprox. $40.00
Jun 22, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Alarm says "wrong cartridge"
That happens when the print head sensor does not detect the cartridge.
To start unplug printer power cord for two minutes, and see if this can reset the error.
The wrong cartridge error may be caused also by a bad cartridge, therefore ,as first step you need to est a different cartridge, possibly a new original one.
Check also if the cartridge metal sensor inside the ink carriage is dirty and must be clean, in this case use isopropyl alcohol and cotton to clean metal contacts inside the carriage.
If that cannot fix the problem, then there is a lose connection on the wires connected to the ink carriage / print head assembly. TWhen that happens, the wires connected at the back of the ink carriage must be tested and eventually replaced.
Apr 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Apr 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Wrong cartridge
I have the multipass mp700 and have just experienced the same message ..... wrong cartridge. After reading the manual, from the disc, it means that there's something wrong with the print head, most likely needs cleaning, but it won't clean because the printer is sending a malfunction message. I will be trying to clean the head and if that doesn't fix it then I'll buy a new print head. Good luck with the problem.
Aug 15, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Display Says Wrong Cartridge
I went to the Canon website and typed "Wrong Cartridge" in the search portion for the MP730. It listed detailed instructions to remove all ink cartridges, raise the lever to the right on the carrier, and then remove / reseat the "carrier". After that I replaced all cartridges and printed the alignment page. All is working, now.
May 11, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon PIXMA MP750 All-In-One InkJet Printer Logo
668 people viewed this question
old marine
old marine
