We have recently purchased a Honeywell DT92E wireless room thermostat. The installer has not left a USER MANUAL (possibly thrown away accidentally with the packaging). Could you please advise where I could locate the manual? We are having no success operating the heating!
  • 17,129 Answers
Please try this link if it will help you:
www.products.ecc.emea.honeywell.com/europe/ecatdata/pdf_???dt92_???dt92a1004.htm
Posted on Sep 28, 2010
I have installed a Honeywell DT92E which keeps turning off the boiler before room temperature is reached
Hello David, I don't know if you installed this thermostsat or had someone else to install it. If you don't have the manual for your DT92E thermostat, I found a PDF file online that coveres both DT92A and DT92A. If you scoll down the PDF file after opening it, towards the bottom, you will see how to adjust the boiler timing. Maybe the timing is still in default mode and needs to be adjusted for a longer burn time? Hope this helps out.
Mar 04, 2014 | Honeywell Heating & Cooling
How do I remove a Honeywell DT92E Thermostat from the wall mount ?
turn off power to thermostat. should be a small flat head screw located on the bottom of the unit. release screw and lift face from the bottom, out and up. you will then need to identify wiring before removal of back plate unless the wiring is redundant.
Nov 07, 2011 | Honeywell Programmable Thermostat Heater
DT92E room stat appears to be very inacurate with its room tempreture, our normal room temp is about 22c we have to set the stat at 25c to get heat and the stat cuts out after a temp rise of 1c
All thermostat is calibrated @ difference of 2 degree.to cut in and cut off.
In heat mode, if you keep 25 and your room temp 23. it will start at the end of 24 or beginning of 25 degree.Cut off also @27 degree beginning. Please check Tips & how to do's in Fixya
Jan 11, 2011 | Honeywell Heating & Cooling
The instructions say the Honeywell DT92E needs only a two wire connection, but the wiring diagram shows three, which is correct Please
This Honeywell control thermostat is made for wireless control, by means of a relay control transmitter with a range of 30 meters. It only needs a 2 wire connection on this stat if indeed it is the DT92E stat. Even though the diagram shows three, you will need only 2 for operation. This is a fact. I have done some reading on this model and many of its relatives, so with built in relays, and transmitters, this is an amazing set-up. Good luck with it as you should enjoy its operation and user friendly features.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Please be kind when rating, as I know you will be. If you have anymore questions, leave them in the comment box so I can check in when I can get to them. Thank you for using Fixya.com
Nov 20, 2010 | Heating & Cooling
Honeywell CT500 Electronic Thermostat showing 73 deg room temp when room temp is actually 77 degs. Can thermostat be calibrated?
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Aug 13, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Accidentally programming it
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 07, 2009 | Honeywell CT500 Digital Heat / Cool Manual...
Honeywell T8011r does not have anything on display - does not appear circuit breaker is thrown - could it be wire disconnected at the plate or is there a fuse inside the unit?
Check to see if you have power at the furnace. You thermostat is powered by 24vac coming from the furnace. You should have power on the "R" terminal.
Oct 05, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
412 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
