If your unit get hit by lighting will it be any good
  • 5,138 Answers
It depends if you got a direct hit by lightning, they are either minor repair or major Damage .
Posted on Sep 28, 2010
My new hot point vented dryer is beeping 3 times when I hit start with the lights flashing, the red clean filter light is staying lit although it is clean??? It's only 6 weeks old
Check the vent system behind the unit, or disconnect it and run the unit. Either way sounds like the vent system is obstructed somehow. Good Luck
Mar 30, 2016 | Dryers
While my wife was washing, the water was turned off to the washer. She hit the pause/cancel button. Now that the water is turned back on, when we hit the start button, all the lights turn off.
Hello,Select any button except start and hold it 4 seconds let go 4sec hold 4sec let go 4sec hold 4sec see if unit goes in service mode all lights will come on hit same button again unit will go into aut test and run a cycle when its done unplug for 5 minutes plug back in and see if unit works.
Jun 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Lighting hit my computer monitor for my desktop. i have an old montior but every time i hook it up the screen goes black and will not show anything. do i need a new one and if so how do i know which kind...
If you have taken a lightning hit, you may have to have your computer serviced.
You could have a number of problems, video card may be no good., power supply may be no good., motherboard may be no good.
The best thing to do is have the unit checked, this way you are not putting good money into bad.
You can find inhome services for under $50.00 or look for a diognists srvice that you would pay, only if repaired.
Sep 30, 2009 | Computers & Internet
My VT-90 will not play
The VT-90 uses 4 CR 2025 batteries. Once you install them you must initialize the unit by holding the "erase all" button for 10 seconds. After a series of blinking the unit is ready again. Good luck.
Apr 01, 2009 | VXI Corporation VT-90 Digital Voice...
How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Apr 01, 2009 | Whirlpool Water Heaters
SA-PT750 rear wireless speakers don't work
Just solved this one thanks to another posting on this site.
Turn all components off.
Check to make sure your wireless card is snugly plugged into the back of the home theatre unit. (Of course you already have. Check again, though, while everything is off.)
Turn wireless unit on first.
Turn on home theatre unit.
The W1 light should be on and blinking red at you (darnit!)
Here's the magic.
Hit the >>/>> button on the front of the home theatre unit WHILE you hit the number 3 on your Panasonic remote.
The screen changes to a P
Then, the wireless unit light should change from red to green (HOORRAAYYYYY!)
If you have multiple wireless units, at this point, you should also hit the Set/ID button on the back of the wireless unit (it is the kind of button that requires something to poke into it to set it).
Then simply hit the >>/>> and 3 at the same time again.
All's good.
And by the way, shame on Panasonic. not only do they not seem to carry these manuals anymore (how hard would it be to have a PDF file and a link on a web page?) but the support info they did have did not contain these steps. Thanks to the FixYa member willray411 for posting this first!
Mar 29, 2009 | Panasonic Audio Players & Recorders
Turning signals dont blink
Problem is the Turn Signal "FLASHER" unit, 1.Turn on Emergency FLASHERS 2. Go under Dash while they are on Listen -for Clicking sound then feel for it 3. Should Be a Silver Round Unit About as Big IN ROUND as Half dollar coin 4. ok now Look Around for the SAME EXACT Thing Clipped onto Something Under dash At Driver side Usually Between Steering wheel and Center HUMP in Floor, 5. once you find it Take OUT the first One you Found Emergency FLASHER) and 6. Put it In Place of Turn Signal Flasher, 7. Turn off Emergency Flashers- Turn Key in "ON" Position but don't start then Try Turn Signals. Yaaaa !!!! they work ?? LoL hopefully this Does the trick, if they work Buy new one and Replace Always Use NEW For TURN Signals as they are used Much More than Emergency Flashers. Hope this is Good Instructions For you and Helps you Solve The Problem, Please DONT Forget to RATE ME Thank you Rejakwilson@aol.com
Jan 18, 2009 | 1986 Oldsmobile Cutlass Supreme
Lights out (front panal lsd lights)
I doubt that any fuse blown ot because the unit still works. The LCD panel in these units are very delicate and can easyly break, also there is a small bulb in there that illuminated the backpanl of the LCD. good Luck
Mar 23, 2007 | Kenwood VR-605 Receiver
Onkyo receiver
It sure dosent sound good!! The clicking sound you here are the protection relays to assist in protecting your speakers from blowing out. Your output devices are shorted it sounds like. Do not ever ever attemp to jump out those relays as it will burn out your speakers and possibly burn down your house!. Theres alot of current inthese amps for high power so if your not a tech and you think its worth it take the unit in to be looked at as there are no serviceable user parts inside these units . Sorry to have to tell ya this.. Good Luck
Jun 05, 2006 | Onkyo TX-DS575 Receiver
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
