SOURCE: dell 5100cn won't recognize mpf tray
Go to the printer web page by entering the IP address of the printer in an Internet Browser.
click Printer Settings menu entry
If the Substitute Tray value is not MPF Feed, click on the Printer Settings tab
Set the Substitute Tray value to MPF Feed
Click the button Apply New Settings, it will request the admin id & password for the printer.
In trying to resolve this issue, initially I set the Tray Settings to Panel Specified from Driver Specified at the printer's panel. Since the issue was resolved with this set, I just left it that way.
SOURCE: Dell 3010cn Not Picking from MPF
When you go to print are you selecting the MPF as the location to print? I have the 3110cn and you must manual select that you want it to print to the MPF.
SOURCE: Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn /
3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn
/ 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's
operator panel, perform the following steps:
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure
1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator
Panel
To verify the paper type matches the type set in the printer's operator
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the
MPF only.
Verify the printing preferences on the Dell™
3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with
the correct paper size, perform the following steps:
The Printers and Faxes
window appears.
The
Printing Preferences window appears.
This sets the size and tray
defaults.
Verify the Paper Size From the Printing Application Matches the Designated
Printer Tray
To verify the paper size from the printing application matches the designated
printer tray, perform the following steps:
Verify the Paper Source From the Printing Application Matches the Designated
Printer Tray
Do not replace any printer hardware as this is not a printer hardware
issue.
SOURCE: CLP-500N Paper Tray error
It wants you to put paper in the multi-purpose or pull down tray 1 assembly.
SOURCE: printer does not recognize that there is paper in the tray
Using the printer panel; you need to change tray paper size from a4 to letter or the size you are using to print on.
An astrick will appear to the right of the size paper that the printer currently has selected.
