Question about Samsung HLR5688W 56" Rear Projection HDTV
Why does my tv shut off on its own - Samsung HLR5688W 56" Rear Projection HDTV
    Genius:
  • 1,622 Answers
It's the problem of overheating in the power supply board of the TV.on the power supply board of the Television there are few capacitors and Integrated circuits.any of this Integrated circuits is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this help in solving the problem, Take care...
Posted on Sep 28, 2010
We have a VizioE420I led smart tv that will just shut off & then turnitself back on at different intervals? we were told by the tv specialist it was the dish satellite box....the dish guy said it was...
Make sure your remote is not shutting off the TV. Turn the TV on and remove the batteries from the remote or take it into another room for a while. If it still shuts off, the power supply unit int the TV is overheating and has a thermal safety that shuts the TV down to avoid a fire. If there is a large amount of dust build up in the back of the TV. Get a can of compressed air and take the TV outside and blow the dust out. This may help.
May 31, 2014 | Vizio L37 Television
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Tv shuts off on start up and light flashes six times
more loose inside your tv that is a reason for your tv shut off you need to resolder the printed board
Jun 24, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
I have a Craig Model CLC501 and have to use both Comcast's control and the TV control in order to shut off TV. I have programmed everything else but can't seem to get tv to shut off with Craig control. Do...
Most cable supplies provide a switched receptacle on the rear of their cable boxes. Plug the power supply for the tv in there if you want the cable box to shut the tv off when you shut the cable box off.
Sep 24, 2009 | Craig Televison & Video
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Lcd tv
What is the model number and mostlikely the set needs the software updated.
Aug 20, 2008 | Samsung Televison & Video
TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Mitsubishi VS-55707 TV
Samsung HLR5688W 56" Rear Projection HDTV Logo
193 people viewed this question
Jerry Greenberg
Jerry Greenberg
