Question about General Hand Tools
I have a b&q rechargeable 1m candle power lantern, how long do I leave it on charge from being flat as the charger unit does not have a led incorporated in it.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
The comments about NiCd and NiMh batteries are misleading. However, they are also irrelevant as this lantern is powered by an RT640 6V 4AH sealed lead-acid battery. It will be permanently damaged if allowed to run down completely.
This battery should be charged using a constant voltage charger. Details on the one I've inspected specify 7.3 to 7.4 volts for normal charging, and 6.85 to 6.95 volts when on standby (at 25 degrees C). The battery will be fully charged when its terminal voltage no longer rises. I don't know whether the charger supplied with this lantern meets these specifications as I don't have one.
Keith Wicks
Posted on Aug 19, 2015
    Guru:
  • 479 Answers
Probably between 3 to 5 hours.
Check battery regularly. It should be warm while charging. When it begins to get hot it is charged. If you charge the battery for longer, there is the increased danger of fire or leakage from the battery.
Note how long the battery has been charged for and during for future charges, reduce the charging time.
NiCad batteries should be run flat before being recharged rather than being topped up in order to get maximum life out of the batteries. This is less critical with NiMh batteries.
Posted on Dec 12, 2010
Why doesn't lantern turn on when not plugged in?
I have a rechargeable spotlight and the directions specifically say not to turn it on while connected to the charger.
Mar 10, 2016 | Coleman Cpx 6 Rechargeable Power Cartridge...
I have the Amertac Westek/Amerelle 75206 LED Rechargeable Candle Kit, 6-Pack2 of the candles don't flicker their just on why is this when I was told their suppose to flicker?
Swap the candles around in the charger. The two in question may not be charging properly or their rechargeable batteries may be defective. Chargers of this type tend to be sensitive to incorrect installation of the candles. I have also found that the candles do not hold a charge very long.
Jun 28, 2014 | Westek Amertac 75206 LED Rechargeable...
I need to know how to recharge my 450 amp jump starter
There is a charging port on the front of the unit next to the LED work light.
The wall charger it came with, is a 12VDC 500ma.
Positive center coaxial connector.
Radio shack usually can match the unit if you bring it in to them.
My charger was pouch Velcro-ed to the unit.
Kings Model KU3B-120-0500D
Jan 27, 2014 | PEAK PKC0BJ 450 Amp Jump-Starter USB Power...
Troubleshoot/Repair Remington MB-1000 Beard Trimmer
If you leave the batteries in the charger with the mains power turned off then the batteries are probably being drained by the charger. Get new batteries and when flat (only flat not just used or part flat) recharge fully then remove from the charger unit. Rechargeable batteries have a habit of developing a memory as if you recharge a part charged battery then it will only recharge to that flat point
May 30, 2013 | Remington MB-1000 Professional Beard and...
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Hi With the rechargeable lanterns that charge by electric or car charger what do you put the lantern on to charge turn it off or put it on on or dc?
You connect the charger to the lamp and plug the charger into an AC outlet. Having the lamp on will increase charge time. The charger does not appear to accept feedback from the battery so it depends on you to disconnect it when charge is complete.
Jan 28, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Hand Tools Logo
600 people viewed this question
Top General Hand Tools Experts
Don Numinen
Don Numinen
Dan Apthorp
Bill Boyd
Are you a General Hand Tool Expert? Answer questions, earn points and help others
