Question about Samsung CLP 315 Laser Printer
Hi, my printer is f...ed up and there is file in memory, so whenever i connect printer to my labtop it start to print about 80 page which sometime i tried to print, but now i dont want it. how can i do that?
    Sergeant:
  • Samsung Expert
  • 406 Answers
Switch off the printer and remove the balance from print driver in notebook or computer
Posted on Sep 29, 2010
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
    Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
    Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
    Dell inspiron labtop
    When you Click File/Print then select Page Setup so that you can change the size.
    Jun 08, 2012 | Dell Computers & Internet
    Page isnt prining out Have new ink in printer
    Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
    1. Print another PDF, such as the first page of Acrobat Help.
    • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
    • If the separate file doesn't print correctly, go to step 2.
    2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
    • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
    • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
    3. Restart your computer, and then print a PDF.
    • If the file prints correctly, your system may have been out of memory or resources.
    • If the file doesn't print correctly, go to step 4.
    4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
    • If the file prints correctly, the printer's memory was too full or had become corrupt.
    • If the file still doesn't print correctly, go to step 5.
    5. Print from another computer.
    • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
    • If the file still doesn't print correctly, go to step 6.
    6. Print a PDF to another printer.
    • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
    • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
    Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
    I'm trying to print a CD with Mac OS 10.6 on an iMac Intel duo with 3 gig memory, and get a message that I need to increase memory. Need a new driver? Ed
    You will probably need to decrease the size of the file, if you work with a big art program you may have unnessesary (spelling?) layers floating in the background. Most printer like having bitmap images sent to them. Vectored images are printed as bitmaps unless you get into postscript compatible printers or some lasers. All else fails put the file on a jumpdrive and print somewhere else to start the process of elimination.
    Sep 22, 2009 | Epson Stylus RX580 InkJet Photo Printer
    Unexpected size in tray 2
    whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
    May 14, 2009 | HP LaserJet 2840 Printer
    Printer "out of memory"
    The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
    1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
    2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
    3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
    4) Go to this website. http://support.microsoft.com/kb/841220
    5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
    6) Download the latest version of Microsoft Works 9.0.
    Let me know if this works.
    Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    Unreadable characters
    check if the file is not currupted.
    and the printer is set for RAW printing, probably dont have enough memory, to print the document
    try printing like only 10 pages at a time to see if the last 10 print
    if it does might want to invest some money in some printer memory
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
    Jul 15, 2008 | Xerox Phaser 8500/DN Printer
    Hp laser jet 4 plus printer
    Need some additional info: -Network based or connected direct to the workstation? -How big are the pdf files? -Has anything changed with the printer, workstation/server host?
    Dec 03, 2006 | HP LaserJet 4 plus Printer
    Samsung CLP 315 Laser Printer Logo
    24 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
