Question about TallyGenicom Tally 5040 Passbook Matrix Printer
My printer,tallygenicom 5040 was paper jam, how to fix that?? thanks before... regards
4 Suggested Answers
SOURCE: tallygenicom 5040 passbook printer problem
Olivetti passbook printer not initialize.
Posted on Mar 07, 2010
SOURCE: Badly jammed Brother HL 5040 B&W laser printer
If you remove the drum unit and cartridge it will all come out in one go.
Open the right hand end. The black T700 cartrige will be seen and it looks as if it is screwed in. However it is NOT just get a firm grip and pull the entire unit out (It snaps in and is quite tight... keep pulling it will come and there are no clips to break as you pull)
As it is removed, all the paper will come out in one go. A bit daunting if you have not done it before. Refit is the exact reverse, push it in quite firmly and it will latch back in place with a pleasing clunk! Hope that helps.
Posted on Jan 24, 2009
208501414
  • 127 Answers
SOURCE: TallyGenicom 5040 printer not detected by
check if your signal cable is working correctly and if the drivers have also been installed right.
thank you
wonder
Posted on Oct 08, 2009
Paper jam error
wash the feeder rubber & clean the sensor of tray unit.
Dec 30, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
How do I get Tally T5040 passbook Printer driver?
Check the manufacturers website (dascom.com):
http://www.dascomamericas.com/Support/Default.aspx?type_id=3&info_id=5&itemid=23&name=T5040&act=4
Jan 07, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
Where to find tallygenicom 5040 driver
http://www.tallygenicom.com/products/productdrivers.aspx?id=5990
Best, Hunter
Mar 02, 2011 | TallyGenicom Office Equipment & Supplies
How to install tally genicom 5040 driver
Have you tried removing the current printer and installing the printer again using the current driver on Tally's website? http://www.tallygenicom.com/products/productdrivers.aspx?id=5990
If this does not work, can you elaborate on the "problem" you are experiencing?
Best, Hunter
Mar 02, 2011 | TallyGenicom 5040 MSR-H - Passbook - B/W -...
Brother Laser 5040 says there is no paper when there is plenty of paper. Have checked for jams and recently replaced drum and toner.
Unplug the printer for about ten minutes. This will clear the NVRAM in the printer. That is where the paper jam's are stored if they get stuck in the printer.
Dec 17, 2009 | Brother HL 5040 Laser Printer
How to clear paper jam in HL 5040 laser printer
Clearing paper jam in a printer is simple almost seven step procedure.
i. Put off the printer.
ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
iii. Now pull out the cartridge carefully.
iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
v. Return the cartridge and press it firmly inside.
vi. Close all covers.
Power on your printer and you should be able to print again.
Dec 04, 2009 | Brother HL 5040 Laser Printer
TallyGenicom 5040 printer not detected by computer. what is the problem?
thank you
wonder
Oct 08, 2009 | TallyGenicom Tally 5040 Passbook Matrix...
Our 5040 tally printer is not being detected by a computer running on Xp and we have tried both parallel and usb cables.
I would guess that the printer is set to use the Serial Interface. I think this is the default interface setting on the 5040, hence the USB and parallel interface will be disabled.
You can change which interface is active from within the printer menu, once you have enabled the USB interface the PC should then detect the printer when you plug it in.
Details on entering the Menu on the 5040 can be found on the Dascom web site; http://dascom.firma.cc/support2/technical_notes/serial_matrix/5040/5040_tn004.htm
Tallygenicom 5040 passbook printer problem
Right, the problem lies in these triangles. They're part of what's called "lower paper feed unit" and are drien by an electromagnet to start/block when needed. This magnet has a tiny problem letting go, so the triangular wheels stop in wrong positions, blocking the paper. The best solution is to change the "clutch" with the latest UCL version (3), you'll know it for having aluminium toothed wheel rather then plastic ones.
Jul 16, 2008 | TallyGenicom 2280 Matrix Printer
TallyGenicom Tally 5040 Passbook  Matrix Printer Logo
243 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
