Question about Canon PIXMA MP780 All-In-One InkJet Printer
Can't print color
Dear expert
help me please, my printer only print black, no color printing, i have tried to clean its cartridge connector, but no result at all color.
thank for your advices
ponimin@telkom.net
  • 20 Answers
Just a thought, have you removed the tape on the top of the cartridge which allows the ink to flow, removing the tape allows air to be sucked through the cartridge.
Another thing you could do, is take all the cartridges out of the machine , remove the printhead from machine, then use a tissue and dab the bottom of the printhead, to see if ink is coming out. If not place ink cartridges on the printhead and place a vacuum cleaner hose on the bottom of the printhead and turn it on, this will force ink through the printhead. Dab Printhead again to see if any ink is there, if not try again. Place back in printer and try printing
Posted on May 27, 2008
The black ink will not print despite being a new full cartridge. The printer sounds as though it is working but the pages are printing out blank. The other colours are working. Help!!!
First thing, make sure the cartridge is seated properly. If so, try cleaning the print head. Normally if the other colors are good and the old black cartridge was working before if went empty try using the maint option and cleaning the print head it gets gummed up sometimes. Also look at the board on the cartridge/cartridge housing (the little gold connectors) and make sure none of them are damaged.
May 03, 2011 | Epson Stylus Multifunction Inkjet Printer/...
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
X8350 All-In-One InkJet Printer: printer does not recognize color cartridge...
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a
dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the
software. Try to print the self test. If failed try another cartridge if you dont get any
error then the cartridge might be defective.
Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at
least "30 seconds." This is essential. Then plug the printer back in and follow these
steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both
(if you have a printer with both color and black installed simultaneously.) Should this
test fail, try it again without cartridges installed. If the self-test still fails to take
paper in and make sounds like the carrier is moving across the paper, this is a hardware
issue, and the printer will require service. If the self-test completes without any
cartridges installed, run the self-test again with the color cartridge installed. (If you
have both black and color cartridges, after this test, run the test again with just the
black cartridge installed.) If you find that either cartridge causes the self-test to fail,
please let me know.
your's tech expert
Jeeth
May 18, 2010 | Lexmark X8350 All-In-One InkJet Printer
HP 6280 printer - the black ink is not printing
You could try removing the cartridge and carefully clean all the little connectors. You can use a screen cleaner.
Mar 19, 2009 | Office Equipment & Supplies
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Missing printed lines form HP Officejet J5750 All in One printer
The cartridges may need to be cleaned by the printer. Check for this option on your user's manual, they will usually refer to it as a nozzle check/clean.
If the cartridge is clogged and does not unclog replace the ink cartridge. Contrary to what people might think these cartridges have a shell life and can be faulty out of the box.
Nov 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Black cartridge problem
Hi , good day , try to do head cleaning until the black print will appear perfect in color.
May 05, 2008 | Epson Stylus Color 460 InkJet Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
54 people viewed this question
old marine
old marine
