Question about Cameras
My PC cannot detect the camcorder (GR-D70AG).
  • Cameras Master
  • 17,129 Answers
Try and see if the driver software needs to be installed , if so use the CD that came along or download from the web.
since you have not confirmed the make/model , unable to find a site to suit your camcorder
Posted on Sep 28, 2010
Jvc d290 cannot connect to pc what program do i need pleas thanks
You computer should detect it without and additional software. Try windows media player. Check to see if you camcorder is detected in windows by checking "My Computer".
Jan 11, 2011 | JVC GR-D290 Mini DV Digital Camcorder
I cannot load pictures onto computer from the JVC camcorder even after I purchased to plug for 6 to 4
that is look like you lost the driver on your pc
is your cam as been detected on pc?
if not you need the driver to be install.
Mar 02, 2010 | JVC GR-D850 Mini DV Camcorder
My Macbook Pro also did not detect the connected GR-DVP9AG
The old Camcorders (which using tapes) need to use firewire 1394 connection (4 t0 4 or 4 to 6) to transfer video to PC/ Mac.
Sep 21, 2009 | JVC Cybercam GR-DVP9 Mini DV Digital...
Can't find driver software with out downloading driver detective
Here is a discussion on JVC camcorder downloading situations. It is somewhat complex with PC. So I'm giving you places I find some answers sometime. So follow the link. -James http://tinyurl.com/jvcpc4109
Apr 01, 2009 | JVC GR-D33US Camcorder
CD lost
All the programs that JVC provides on their CD is uploaded at the link below.
http://support.jvc.com/consumer/custrel/index.jsp
Sep 02, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
JVC GR-DVP7 - Video to PC / Firewire Cable ... where can I get one?
Best Buy has a 6 pin to 4 pin firewire cable. You will need some software as well to copy to the hard drive such as Pinnacle Studio if you don't have on already.
Once the cable is plugged in and turned on Studio will detect the camera and run the program.
Jun 24, 2008 | JVC Cybercam GR-DVP7 Mini DV Digital...
JVC GR-DVL310 VISTA DRIVER
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310U
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310UM
Jan 20, 2008 | JVC GR-DVL310 Mini DV Digital Camcorder
CAMCORDER RECOGNITION BY PC
It will recognized if you select it manually: when prompt what DigiCamcorder INSERT the CD installer of your camcorder to detect your unit in the firewire.
Dec 11, 2007 | JVC GR-D73E Mini DV Digital Camcorder
Software needed for JVC as JVC seems Unable to assist from there Websites
same problem here... i tried to using USB cable to connect to a computer but the camcorder cannot be detected.
Nov 17, 2007 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
Cameras Logo
32 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
