Question about HP PSC 750 All-In-One InkJet Printer
Started with out of colour ink - changed coluor ink cartridge. then came up with out of black ink - so changed the black ink cartridge now sais scanner failure when run through procedure to align cartridges. what is the problem and solution to fix it
  • 240 Answers
"Scanner failure" basically means buy a new machine. Once the scanner fails on an all-in-one it will refuse to do anything. Replacing or fixing the scanner will cost much more than buying a new machine.
Posted on Sep 28, 2010
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
How do i change the colour cartridge for a epson style c42+ printer - if i press the red LED button for 6 secs only the black cartridge comes into the open.! how do i get the colour cartridge into view ?
after the black cartridge moves to the ink changing position, push the 'ink' button one more time to move the carriage to the position to replace the colour cartridge. in some cases this will only work when the printer indicates that the color cartridge is empty.
Oct 12, 2009 | Epson Stylus C42+ InkJet Printer
How do I change the ink cartridges on a canon mp210
tget the manual free copy this site and paste it in your ADDRESS BAR and hit ENTER.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
(14) FINE Cartridge Holder
Install the FINE Cartridges here.
The Black FINE Cartridge should be installed into the left slot (ug_before_printing6.jpg) and the Color FINE Cartridge should be into the right slot (ug_before_printing7.jpg).
(15) FINE Cartridges (Ink Cartridges)
A replaceable cartridge that is Print Head and ink tank integrated.
i_note.gif Note
For information on how to install the FINE Cartridges, refer to your setup sheet.
(16) Scanning Unit (Printer Cover)
Scans original documents. Open it when replacing the FINE Cartridges or removing jammed paper remaining inside the machine.
This is in the first part of the Manual.
Hope this is of some help. Bud
Jun 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 750 All-In-One InkJet Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
