Question about HP iPAQ RZ1710 Pocket PC
When I cradle my iPAQ it takes hours to syn with my laptop. I deleted and setup a new partnership after being away and brought the iPAQ home and connected to Laptop it wouldn't recognise it. Setup new partnership and it recognises it, but when the iPAQ sync it take so long and never finishes sync. What do I need to do?
  • 944 Answers
This problem could occur due to two reasons:Phone firmware corrupted or its problem with laptop synchronization software.
1)First reset the phone follow the below link about how to reset the phone.Do hard reset not soft reset.
http://www.hardreset.eu/hp_ipaq_rz1710_hard_reset_soft_reset_en.html
2)Uninstall and reinstall the phone sync software again and restart your system.
3)Check the usb connection is good and not defective.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 28, 2010
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
I have an IPAQ 3950 PDA, I bought a in car charger from ebay and after using it my PDA no longer works. It will not switch on, charge on its home cradle or connect to my laptop, the IPAQ is completely...
Thath iPAQ have two security fuses inside,, maybe one blows up when you connect that charger,,, this is not an easy repair work,, you need to have advance experience on electronics,, or take it to an expert service shop,,, good luck!!
Jun 30, 2008 | LG KU990 Viewty
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Removing/restoring partnership
acc to me, partnership once deleted due to hard reset on ur smartphone will not be created under the same name until u delete the same partnership from active sync on pc. To delete the partnership open active sync>file>delete partnership..then create new with the same name with ur smartphone.
hope this will help
Sep 19, 2005 | HP iPAQ HX4700 Pocket PC
3970 Stuck
Try this, take the ipaq off the cradle, turn the ipaq off (if you can), restart the desktop, put the ipaq back in thc cradle, turn the ipaq on, and restart ROM update again.
Sep 12, 2005 | Compaq iPAQ H3970 Pocket PC
Connection with my iPAQ 3660
...USB and Serial cradles and cables from... http://www.pdasmart.com/ipaqparts3600.htm http://www.amazon.com/exec/obidos/A...1&link_code=as1 http://www.bizrate.com/buy/noncat_p...--37673232.html There are probably other sites, but these are a few from a quick search... Otherwise, yes via IR if the PC your synching with has IR functionality... BT and WiFi also, but you need to establish a partnership via USB/Serial/IR first... Go to this site and download the Reference Manual, etc... http://h18000.www1.hp.com/support/f...te/48_1334.html You can get the latest version of ActiveSync from... http://www.microsoft.com/windowsmob...tivesync37.mspx __________________ "When all else fails, read the instructions..."
Sep 12, 2005 | Compaq iPAQ H3660
IPAQ rx3115 calendar synch 1 hour off
The pc clock needs to be set to daylight savings time. To do this right click on the time on you pc go to the time/clock settings and then click on the time zone tab and below the clock is the box that says automatically adjust for daylight savings time make sure that is checked and then re-sync the iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Please help! Cannot sync....
You need to install Activesync onto your PC. Activesync comes on the CD that came with your Ipaq , or the latest version can be downloaded from here... http://www.microsoft.com/downloads/details.aspx?FamilyID=2eb5bd80-d52c-45 60-ae11-da92f2b229fa&DisplayLang=en Then from your PC (not your IPAQ), open Activesync, click on File, Get Connected and do NOT cradle the IPAQ until it tells you to. The Activesync on the IPAQ is for wireless syncs, which cannot be done until youu establish a partnership with this first wired sync. You will need a wireless network to do a wireless sync.
Sep 07, 2005 | HP iPAQ RX3700 Pocket PC
IPAQ 4150 - Sync Problems
It might be a hardware problem - if you get it both with the cradle and a sync cable, then it might be the connector at bottom of Ipaq. But I don't know for sure. If it's intermittent like this then it doesn't seem like a software problem.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
HP iPAQ RZ1710 Pocket PC Logo
67 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
