Sony cdx-1480 connector pinout - Audio Players & Recorders
Sony cd player, CDX-3100 wiring diagram
This is the pinout shown on the Sony website for the CDX series players. Pin numbering is as follows:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
This is looking at the connector with the wires towards you.
Pin Number Wire Color Description
1 White Left front +
2 Green Left rear +
3 Purple Right rear +
4 Gray Right front +
5 Blue/white AMP Remote
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
9 White/black Left front -
10 Green/black Left rear -
11 Purple/black Right rear -
12 Bray/black Right front -
13 Sky blue ATT
14
15 Orange/white Illumination
16 Yellow Battery
Feb 24, 2010 | Sony Car Audio & Video
I need to know where the wires comming out of the plug go to?? wiring diagram. thank you sony cdx-3100
1 2 3 4 5 6 7 8
2 Green Left rear +
6 Blue ANT Remote
7 Red Accessory
8 Black Ground
13 Sky blue ATT
14
16 Yellow Battery
Jan 05, 2010 | Sony CDX-3100 CD Changer
Unhooked the harness in order to install an FM modulator. Now, after plugging back in, I get no power on. Any ideas?
Have you tried resetting the unit? Here is a link to Sony for your CDX-4000X operating instructions. Reference page 6 for the reset proceedure.
http://www.docs.sony.com/release/CDX4000X.pdf
And here is a link for wiring pinouts, fuses....etc.
http://www.docs.sony.com/release/specs/CDX-4000X_Spec_Sheet.pdf
Dec 04, 2009 | Sony CDX-4000X CD Player
Would like to connect i pod into my system, but have no instruction book or wiring diagram. The model is a Sony CDX 5470 RDS
I just did this yesterday with my Kenwood MP8017 and an old Dell Pocket DJ. The deck uses a 15pin DIN connector. I had the connector and just used trial-and-error to determine the left, right channels and ground.
For your setup, you need to first determine what sort of inputs that the Sony unit has. Most have some sort if DIN input. If there is an AUX input, you are good to go as it is simply GND, Left and Right Channels. Then use this to deterime the signal pinouts from the IPOD cable.
You will have to hack up an IPOD docking cable (you can get them cheap here.). and get an 3.5 mm jack to cut up as well.
If your deck uses a DIN connector, you will have to source one of those and determine its pinout. Then, just match it with the IPOD connector and you are good.
Apr 20, 2009 | Sony Car Audio & Video
Remove CD Magazine - No power to unit!
I fixed my similar problem by applying 12v to the unit according to the pinout found here:
http://users.ntplx.net/~andrew/sony/unilink/
(note that -12v goes to the connector barrel)
Apr 26, 2008 | Sony CDX-656 10-Disc CD Changer
Connecting To Auto Harness
Most Sony head units follow the ISO standards in its wiring and connector pinouts.
A Sony CDX-S2000 would be using the below listed wiring:
Yellow - +12V Constant Power (such as the + terminal of your battery)
Red - +12V Switched Power (such as the ACC of the IGN switch)
Blue - Power Antenna
Blue/White - External Power Amp Turn-on trigger
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
In some models, Sony would have several versions of the connectors depending on the region the unit was intended for use, 10. 16 and 18 pins. The connector (loom) would have to match what your version has. They are readily available from most auto stereo stores and on line. You can try here or here .
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 07, 2008 | Sony CDX-S2000 CD Player
82 people viewed this question
 Grubhead
Grubhead
