Question about Frigidaire Washing Machines
I have a Frigidaire Stackable washer dryer it is approx 3 years old but only used about a dozen times the rest of the time it has been in storage until two months ago when I moved and the movers dropped it out of the truck and left it out side when I arrived at the new place three days ago I brought it in and cleaned it up making sure all was dry and pluged it in every thing works but the spin and drain but you can hear like it wants to work and there is power going to the pump and motor any idea what the problem is?The model number is; MEX731CFS1 and it did work befire and also I did not add clothes or water to it to ytest my concern was just to see if the washer would work in all functions it does but with out spinning I can hear the pump click on so I assume it would be ok but still no spinning
  • 1 more comment
  • Leighton Hurry Sep 28, 2010
    thanks for your advise but all that was checked the lid switch was broken but I had replaced it but still same problem I have checked the circut board for damage under bright light and magnifie glass looking for hair line cracks and all checked out good I feel it still has something to do with the lid switch as that apeared to be the only thing that broke but they are pretty much very straight forward can't really make a mistake reinstalling a new one
    I did check to see if the tub will spin manually and does .As I have mentioned you can hear a humming from the motor but that is all I did replace the switch for the lid and when the lid is opentthere is power going thru the line but close it and the power shuts off its starting to give me a head ache
  • Leighton Hurry Oct 01, 2010
    Thank you that helped i removed the motor and replaced it and now all is good thankyou for the help
  • 11,896 Answers
If there is no spinning action, then either motor or belt is disconnected. Unless you have a transmisson, than they may be bad or disconnected. Try spinning your tub by hand and see if it spins freely. It should. If not, the bearings could be jammed.
Posted on Sep 28, 2010
  • Nate Stansfield
    Nate Stansfield Sep 28, 2010
    Try removing the belt from the motor and see if it spins then. Sounds like you may have a weak motor.
  • Frigidaire Master
  • 19,396 Answers
Re:every thing works but the spin and drain
Check the lid switch, the main controller board (CCU) performs an extra check on door lock switch before advancing to spin.
Check and eventually replace the pressure switch. The data from pressure switch tell the CCU when drain is complete and when to start spinning, or when to start the drain pump.
Check wiring.
Check the CCU. If the appliance received a shock, then the PC board may be faulty with broken solder joints. Full test is done disconnecting power and reading Ohms on all soldering joints, to ensure that there is continuity (circuit not open). Pay particular attention at drain pump, door switch and pressure switch wiring and solder joints.
Let me know how it goes. If this solution was helpful, then please do not forget to accept.
Regards.
Ginko.
  • Ginko
    Ginko Sep 28, 2010
    Hi.
    I see that I received bad rating for my answer. I mentioned the pressure switch, and I said about TESTING the CCU. That means not examining with a magnifier, but using a multimeter to check solder joints and components. That is the only way to test an electronic board.
    About the pressure switch , TRY REPLACING IT, it is $15 or so, and it is difficult to test.
    Those are the only common failures that cause cycle interrupting before spinning.
    I think I just wasted my time with your problem here, on your request the problem had been passed to a different expert. Considering that I was online, and I already posted a solution that is far from ideal.
    Goodbye and good luck.
    G.
Frigidaire stackable washer and dryer...model # GLET1031CSO was drying clothes, opened dryer to check, will not come back on. Washer still wroking fine. Can you help me? I checked breaker, it is fine....
Sorry to read about your problem, I hope this helps you out.
You may have a defective door switch, or lost a control board.....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Frigidaire Washing Machines
I have a Frigidaire stackable full-size washer/dryer. I don't have the model number, but it is about eight years old. The dryer does not get hot enough to dry even a small load well.
When was the last time you cleaned out your vent? It should be done every 1-2 years to prevent build-up of lint and possible blockage. Also make sure your outside dryer vent flap is not stuck closed or clogged. I use a plumbers snake to twist inside the vent and clean out the lint. It makes a huge difference in drying time. Also disconnect the vent from behind the dryer and check for lint build-up inside the back of the dryer itself. (Be sure to unplug the dryer before you do this!) When you push the dryer back, be careful not to squish or pinch the dryer vent if it is a flexible foil or plastic tube. These are the easy fix-it's. Try them first before resorting to more expensive trouble shooting. Douglas
Sep 06, 2010 | Frigidaire Dryers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Hi, my stackable frigidare dryer isn't doing a very good job drying my clothes. The unit is about 3-4 years old, but has only been used for 2 years.
Make sure the vent is completely clear and the air blowing out is a pretty strong flow. It could be a defective thermostat too. Another reason is sometimes the washer doesn't spin the clothes out enough and they are too wet to dry normally.
Jan 06, 2010 | Frigidaire Dryers
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
215 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
