Question about Apple iPhone Smartphone
My iphone cannot turn on after i reset all settings.
How to factory reset
Is your phone an iPhone, Android or else? You'd better provide more info to get help. For Android phone, it should be likely to go to "Settings > Backup & Reset".
Dec 22, 2015 | Cell Phones
Tip
How to format Iphone.
  • Turn your iPhone on. Hold down the "Power" button at the top right corner of the iPhone until the Apple logo appears.
  • 2Tap the "Settings" button on the "Home" screen of your iPhone. This is a gray icon with an image of gears on it.
  • 3Tap the "General" tab. This opens the general settings of your iPhone.
  • 4Scroll to the bottom of the "General" settings window and tap "Reset."
  • 5Tap "Erase all content and settings." A warning will pop up indicating that all media, data and settings will be erased and reset. Tap "Erase iPhone" to format the entire iPhone.
  • on Nov 23, 2010 | Cell Phones
    Tip
    My Apple Iphone wont turn on. What to do when Iphone is freezing.
    Hi.
    What do I do if my Iphone does not start up anymore?
    Here basic troubleshooting:
    1 Try turning Iphone off, then back on. Turn it off by holding down the Sleep/Wakebutton until you see the red slider on display, then slide the finger across theslider. To turn iPhone back on, hold down theSleep/Wake button until the you see Apple logo on display.
    2 Try pressing and holding the Home button for about ten seconds. This will close a frozen application or a stuck process. After this restart the iPhone following thesteps on point one.
    3 If the above did not work, try doing a reset. Hold down the Sleep/Wake button and the Homebutton at the same time for about 10 seconds. You may see ared "power off" slider appearing on screen, then you see the display going black. Donot release Sleep/Wake and Home buttons until you see the Apple logo appearing on display. See picture below:
    4 Reset all settings: Tap Settings>General>Reset> Reset All Settings. This will reset all settings to factory default. Data and media files will not be affected.
    5 If that does not fix the problem, then try deleting all content and settings.
    Tap Settings>General>Reset>Erase All Contents and Settings
    This will delete all media and data. All settings will also be reset to default value.
    6 Try restoring iPhone using the latest version of iTunes.
    Connect iPhone to the computer using the data cable. When you see the IPhone in the Source list, click on Restore in the Summary tab.
    If that did not work, repeat steps from 4 to 6 once more. If Iphone is still frozen, unplug it from pc, and try restarting the Iphone. Also reinstall Itunes and connect Iphone to pc again.
    Ifrepeating the steps 4 to 6 did not fix your problem , then the Iphone isfaulty. In that case take it to a local Apple repair shop, or call Apple servicephone number listed on the user guide to arrange repair.
    If the Iphone is faulty, sometimes reinstalling Firmware can fix it, but that, that is a risky procedure that will invalidate your warranty and damage the IPhone beyond repair. Better calling Apple before bricking the Iphone.
    For this reason I will only post links on the argument.
    On firmware update see:
    How To Install IPhone Firmware
    IPhone Firmware Download Links
    Regards.
    on Mar 22, 2010 | Apple iPhone Smartphone
    How do you factory hard reset a apple iphone with the model number A1332 an no sim?
    iTunes enables you to restore iPhone to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPhone with iTunes as follows.
    1. Plug iPhone into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
    2. Click the name of your iPhone at the upper right corner of iTunes, and then the information of your iPhone will be shown. Click the "Restore iPhone" button in the window to start.
    3. iTunes will ask whether you want to back up iPhone before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone. Then iTunes will start restoring your iPhone to factory settings.
    4. Click Restore again to confirm. Then iTunes erases your iPhone and installs the latest iOS software. After you restore your iPhone to factory settings, it will restart. Now you can set it up as new.
    How to Restore iPhone 6 Plus to Factory Settings
    Aug 28, 2014 | Apple iPhone Cell Phones
    My phone won't charge
    Try these in this order until the issue is resolved:
    1. Restart the iPhone
    2. Reset the iPhone (Hold power and Home buttons until iPhone turns off)
    3. Settings > General > Reset > Reset all settings
    4. Bakup manually to iTunes then Restore iPhone via iTunes and set up as a new phone. (if issue persists then you have a hardware problem and need to get the iPhone 5c replaced by Apple)
    Jan 20, 2014 | Apple iPhone 5c
    Tip
    Apple iPhone hard reset If iPhone won?t turn on, or if the display freezes or...
    If iPhone won’t turn on, or if the display freezes or doesn’t respond
    •Press and hold the Home button below the screen for at least six seconds, until the application you were using quits.
    •If that doesn’t work, turn iPhone off and turn it on again. Press and hold the Sleep/ Wake button on top of iPhone for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    •If that doesn’t work, reset iPhone. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
    Updating and Restoring iPhone Software
    You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
    If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
    1.Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
    2.Connect iPhone to your computer.
    3.In iTunes, select iPhone in the Source pane and click the Summary tab.
    4.Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available.
    5.Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
    Resetting iPhone Settings
    Reset all settings
    Choose General > Reset and tap Reset All Settings.
    •All your preferences and settings are reset. Information, such as your contacts and calendars, and media, such as your songs and videos, are not deleted.
    Choose General > Reset and tap “Erase All Content and Settings.”
    •All your information and media are deleted. You must sync iPhone with your computer to restore contacts, songs, videos, and other information and media.
    Reset the keyboard dictionary
    Choose General > Reset and tap Reset Keyboard Dictionary.
    •You add words to the keyboard dictionary by rejecting words iPhone suggests as you type. Tap a word to reject the correction and add the word to the keyboard dictionary. Resetting the keyboard dictionary erases all words you’ve added.
    Reset Network Settings
    Choose General > Reset and tap Reset Network Settings.
    on Mar 10, 2010 | Cell Phones
    My iphone can connecto wifi but cannot receive data
    turn off the phone
    hold the home button while turning the phone on.
    Settings --> General --> Reset --> Reset Network Settings.
    Sep 12, 2009 | Apple iPhone 3G
    Iphone not working after update
    do this for ur iphone.
    plug it in the computer and turn it off (the iphone and make sure itunes is open)
    now u are going to hold the top and bottom button for ten seconds then release the top button and it should go in to recovery mode the comp will recognise it and will say " an ipod/iphone has been found in recovery mode' now u need to restore it and it will be fine.
    Sep 14, 2008 | Apple iPhone Smartphone
    HELP !!!!
    Here's what you should do: 1. Press and hold the Home button below the screen for at least six seconds, until the application you were using quits. 2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears. 3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. If it continues to freeze 1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted. 2. If that doesn't work, erase all content on iPhone. From the Home screen choose Settings > General > Reset > Erase All Content and Settings. All your preferences and other data are removed from iPhone. 3. If that doesn't work, restore the iPhone software.
    Jul 01, 2007 | Apple iPhone Smartphone
    Apple iPhone Smartphone Logo
    59 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
