Question about Insignia Pilot MP3 Player
Insignia Sports 4GB Headset Jack Problem
I had my player for about 4 months and now the headset jack is messing up, it has to be held at a certain angle in order for music to be heard....is there a way it can be fixed?
  • 28 Answers
Just press the headset jack pin inside properly n u will be enjoying the music again
Posted on May 24, 2008
  • gaurav dhanwani May 24, 2008
    just press the headset jack pin inside properly n u will be enjoying the music again
Vox on cobras is on head set is working but still hear voice thru the radio as well
Assuming you have the correct headset match to your radio... Two things to check:
1) Be certain your radio is turned off when plugging in the headset.
2) Be certain you seat the 2-pronged plug completely. You should feel a click when the device is fully plugged in. If your audio accessory jack on the radio has never been used it will be a tight fit in the beginning. Also, in saying this, if you plan to always use the headset, leave it plugged in. This will avoid needless wear-n-tear on the jack.
Best regards.
Sep 03, 2013 | Motorola RDU2020 Two Way Radio
How can i fix the headphone jack on my iriver H10 6GB?
What i would recommend you to do is to use a different headphone jack....I am a DJ also and certain headset doesnt work properly when you have it all way..try a different one and let me know the outcome..
Thank You
Computerrep
**Please rate accordingly***
Jan 30, 2008 | iRiver H10 MP3 Player
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
Is the creative hs-400 compatible with regular mp3 players?
It should be compatible with any MP3 players.
The headset has a universal headphone jack that is compatible with most (if not all) devices.
Apr 16, 2011 | Creative Labs HS-400 Headset
No sound out of dvd player speakers but headsets work
it could be that the jack where you conect the Headset is locked on headset when you unplug the headset it should go to speakers.
ecrdn@yahoo.com
Jack
Oct 20, 2010 | Dynex DX-PDVD7 Portable DVD Player
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
Why do I hear music coming from my MP4 player when I have the earphones plugged in?
There is a switch inside the player headset female jack that is deactivated by headset the male jack when it is plugged in. The switch deactivates the outside speakers. In your case, the switch is not deactivated so you hear sound from both. Three things may cause the problem that you need to check.
  1. You are using a not compatible headset. Make sure headset used is compatible with the player.
  2. The headset is not properly inserted. Insert the headset firmly and make sure it sits firmly in.
  3. The switch inside the unit is defective. It may be stuck or broken. Disassemble the unit to check the switch. Insert the headset and make a visual check if it hits the said switch and deactivates it. You may need the help of a person with know-how in electronics.
Nov 07, 2009 | Konaki MP4-NS MP3 Player
Only one audio output working - not stereo!
It is the actual headset jack on the device. It wears out from plugging and unplugging the headset.
If its less than 1 year, call SanDisk and they will replace it.
Otherwise, if you are inclined, you can replace the internal headset jack.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Nov 11, 2007 | SanDisk Sansa e260 MP3 Player
Headset jack
If its less than 1 year, you can call SanDisk and they will replace it.
Sep 02, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Headset jack
http://www.zenrepair.com/Zen/index.jsp
http://repair4player.org/disassembly_creative.html
Dec 11, 2006 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Insignia Pilot MP3 Player Logo
51 people viewed this question
Top Insignia Audio Players & Recorders Experts
tk007
Level 1 Expert
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
