Question about HP LaserJet P2015dn Printer
I have HP LaserJet P2015 Printer , which prints light, i need to print dark but there is no option in setting area for the adjustment of ink volume etc.
  • HP Master
  • 17,130 Answers
If you check on the Printer Icon the properties will open out in which the contrast and settings can be set accordingly and tested
Posted on Sep 28, 2010
The attention light comes on when i want to print
some times this printer problem on toner chip.some times problem processing print defective on LSU
Aug 10, 2016 | HP LaserJet P2015 Printer
P2015 laserjet printer is giving black printing
Hi check the toner, if you have one for testing may be old and will take away the doubt
Jun 30, 2014 | HP LaserJet P2015 Printer
My printer HP laserjet P2015, have a problem that no error light blink ready status light on (GREEN) but no test print out and nor other printing by USB cable from computer. Please advice about this i
May be cable loose or heavy dust available in printer that`s why your printer not proper response it. Or may be printer main board damage position so i suggest you contact it printer technician or checking it, which area damage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764440&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3811075
Thanks,
HP Printer Support
May 15, 2014 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
How to add NIC in HP color laserjet CP1215 Printer?
If this model HP does not have an expansion slot for a HP Jetdirect Print server, then to use this printer on your network you have two options.
1. Connect the printer to a desktop computer on your network and set it uo as a shared printer. This means this computer and printer needs to be powered up for the other computer on your network to print to the shared printer.
2. Connect the printer to a print server that is connected to your network.
Nov 24, 2010 | HP LaserJet P2015 Printer
I have a HP LasterJet P2015. I am trying to print multiple page PDF file documents and after one page has printed, the triangle and "!" light flashes and a print out says insufficient memory. How do I...
Open Printer options and reduce the print quality. It is probably 1200dpi. Make it 600 and try the print again.
You may also add more printer memory to print complex documents on highest resolution possible.
Aug 06, 2010 | HP LaserJet P2015 Printer
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
Can't figure out how to adjust darkness/tone for printer output
Below you can see a step by step procedure on how to change the print quality of your work....you need to make test printouts in order for you to see the results....at the end there is a link to the manual for your printer...GOOD LUCK!!!
Print-quality settings affect print resolution and toner usage.
Use the following procedure to change print-quality settings:
1. Open the printer Properties (or Printing Preferences in Windows 2000 and XP).
2. On the Paper/Quality tab or the Finishing tab (the Paper Type/Quality tab for some Mac drivers),
select the print quality setting you want to use. The following options are available:
● 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
● 1200 dpi effective output quality: This setting provides 1200 dpi effective output quality
using FastRes 1200.
● 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology
(REt) for improved text.
● EconoMode: Text is printed using less toner. This setting is useful when you are printing
drafts. You can turn on this option independently of other print-quality settings.
Manual
Apr 13, 2009 | Office Equipment & Supplies
HP LaserJet P2015dn Printer Logo
744 people viewed this question
Seeker5211
Seeker5211
