Question about Canon MultiPASS C70 All-In-One InkJet Printer
Can't find its driver
Tired with the driver for my C 70
Can i download this printers driver cd plz replay imideatly
Posted on Jun 20, 2008
Replace stock tire size.
Look at the sticker on the drivers side or passenger side door and you will see the manufacture recommended allowed tire size on your stock rims.
Feb 18, 2014 | 2002 Chevrolet TrailBlazer
Need new tires
Open the drivers door
The proper tire size is on the white
B-pillar label
Your engine light is a separate issue that
a repair shop or dealer can diagnose for you
Jun 20, 2012 | Cars & Trucks
Recommended tire size is 2352/70/R15 can I change sizes?
I don't believe there would be a problem due to fit but this is difference in measurements.
The 75 diameter (across tire) is 28.88 in.
The 70 diameter is 27.95 in
The 75 width of tire is 9.25
The 70 width is also 9.25
The 75 circumference 90.72
The 70 circumference 87.82
The 75 sidewall height 6.94
The 70 sidewall height 6.48
The 75 revolution per mile 698
The 70 revolution per mile 721
The 75 speed at 50 and the 70 is 48.4
I can't see why it would not work.
Aug 03, 2017 | 2001 GMC Jimmy
What size tires does a 2001 mitsubishi montero sport v6 engine use please?
The tire size depends on the vehicle trim level. Below are multiple trim levels and their respective tire sizes.
ES 235/75/15
LS 255/70/16
Limited 255/70/16
XLS 255/70/16
XS 255/70/16
The best thing to do if the vehicle is available is to inspect the tire sidewall for what the current equipment is. There is also typically a sticker in the driver door jamb, center console or glovebox stating the proper tire size & inflation.
Feb 14, 2011 | 2001 Mitsubishi Montero Sport 4WD
What size tires originally on jms 1995 jimmy
There were a few different sizes originally available on that vehicle depending on options. If it is 2wd it could have come from the factory with a 205-75-15 or a 235-70-15 tire. If it's 4wd it could have come with a 235-70-15 or 235-75-15 tire. There should be a tire placard on the door jam of the drivers door stating original equipment tire sizes and recommended inflation pressures.
Sep 05, 2010 | 1995 GMC Jimmy
What is the recommended air pressure in the tires P215 70 R15
It is probably between 32 and 35psi. If you open the drivers door and look in the jam there will be a placard listing the recommended tire pressures. If it's not on the drivers door it may be on one of the passenger doors.
Aug 02, 2010 | 2001 Buick Regal
What is the original size tire and rim for a 1997 expedition
The best way to find out is the door sticker on the driver side door.
There are two possibles sizes for that truck. The 16" rim or 17" rim.
The tire size is P255/70R16 or P265/70R17.
The factory sticker on the door jam on the driver side will tell you what it came out of the factory with.
Jan 25, 2010 | 1997 Ford Expedition
What is the proper tire size for a 2000 caravan
If you want to know the correct tire size for your vehicle. Open the drivers door and look on the edge of the door under the latch. You should find a data plate that will tell you size of tire for your van and proper air pressure for front and back tires.
Oct 14, 2009 | 2000 Dodge Caravan
Tire and Rim Problem
It appears that you have the wrong size wheels on the rear (17). Standard tire size on that vehicle is 265/75/16. You all so have a full size spare. Keep in mind that if this is a 4 wheel drive vehicle, damage to the drivetrain can result if you continue to drive with diffrent size tires.
Aug 06, 2009 | 2003 GMC Yukon Denali
Canon MultiPASS C70 All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
