Question about Apple MacBook Pro Notebook
How can I unlock my macbook pro keyboard, no key strokes appear
  • JG1977
    JG1977 Oct 05, 2010
    are you connected via bluetooth or usb?
  • 863 Answers
If this is not a unibody, then remove the rechargeable battery and check that the keyboard ribbon is securely fastened. If that doesn't help then you got to open this puppy up and see if the power ribbons are properly seated to the logic board.
Posted on Oct 06, 2010
Bad keypads macbook pro 17
First, try plugging in any USB keyboard to your laptop to try the "problem keys" be sure it's just your laptop's built-in keyboard that's messed up.
PowerbookMedic.com sells the built-in keyboard that goes in your 17" MacBook Pro for about $85. That will probably take care of the problem, but check iFixit.com for a guide (with pictures) on how to replace the keyboard, to assess whether you're comfortable undertaking the task.
Jun 07, 2014 | Apple MacBook Pro PC Notebook
Restart appears on start up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 26, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Nov 22, 2012 | Apple MacBook Air
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
My keys lock up completely sometimes...i think i'm hitting some command on accident. how do i unlock w/o shutting down?
First check in the Universal Access pref pane and uncheck Enable access for universal devices or be sure Mouse keys is off as well as Sticky keys.
Try closing the lid and reopening.
Check for any third party mouse software (Iike Logitech) that may be interfering.
Test with an external keyboard to rule out software.
Failing to find an answer in software, you may have a problem with the keyboard connection internally. If you are under warrantee or have Applecare, take it to them to possibly have the keyboard replaced. Otherwise, check out this link on how to check and fix a possible hardware problem:
http://gigaom.com/apple/the-curious-case-of-the-missing-macbook-pro-keyboard-and-trackpad/
Nov 07, 2010 | Apple MacBook Pro Notebook
Keys not working
First off, you need to determine whether the keys themselves are faulty, or whether you just have your system set up to ignore them.
Go to Apple Menu / System Preferences / Language & Text (this is on Snow Leopard, on Leopard I believe you have to look under International). Turn on "Keyboard and Character Viewer" and "Show input menu in menu bar." Now on the Menu bar, you will see an icon of a box with an asterisk in it. Choose "Show keyboard viewer." Now type the arrow keys and see if they blink on the keyboard viewer. If they do, there is nothing wrong with your keyboard; you just have somehow set those keys to have no effect (and figuring that out is another issue). If they do not blink, you have a hardware problem in your keyboard that will require keyboard replacement.
Services like laptopkey.com will NOT help you, as they sell only key CAPS, and the problem is in your key electronics.
A MacBook Pro keyboard is NOT a user-replaceable part.
May 05, 2010 | Apple MacBook Pro Notebook
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
Apple MacBook Pro Notebook Logo
1,346 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
