Question about Hotpoint Ultima WDM73 Front Load Washer / Dryer
Washer/Dryer wdm73 door will not unlock
Yesterday while washing the fuse went in the washing machine, so i changed the fuse and started the cycle again, when it's finished it keeps saying spinning across the screen so i press cancelled the screen goes back to select programme but the door will not unlock, I turned it off at the plug and mains but when turned back on the door will still not unlock.
Please help i have a washer full of clothes.
many thanks
  • Hotpoint Master
  • 19,396 Answers
  • 2 more comments
  • Ginko
    Ginko May 24, 2008
    Disconnect machine from power for 10 minutes, this will reset eventual electronic problems.
    First try to unlock the latch, pushing , then pulling it out.
  • Ginko
    Ginko May 24, 2008
    Try also pressing "end of cycle" button, then wait for 2 minutes before opening the door, this may unlock the sensor
  • Ginko
    Ginko May 24, 2008
    If after the above it still does not open then you will need to have the door forced to open by a repairman, in this case, if you live in UK/Irl you can check the contact at the end pages of the manual here, otherwise check contact for your area on hotpoint website.
  • Ginko
    Ginko May 24, 2008
    One last thing, if you still have water filling the drum, door will not open, drain the water using the cycle before attempting the steps above.
My Hotpoint wdm73 won't drain. how do I fix it?
  1. You will need to gain access to the drain pump through the bottom of the Washing machine. Remove the Drain hoses from the pump, clear any debris, change, etc. If it is clear, or the error continues after clearing, replace the drain pump.
  2. If you replace the drain pump and it still won't drain, you will need a new Control Board.
Feb 27, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Door stays locked at end of cycle
If still has water in it thats your answer, needs cleaning filter....
Feb 09, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Jun 19, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Machine starts and comes up with refer to instructions code e30
This relates to a motor problem and may be the motor brushes or yours might have an inline fuse on one of the motor wires. (Check the loom back to the pcb).
Jun 03, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Plz rate my solution
Jan 22, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Hotpoint Ultima WDM73 Front Load Washer / Dryer Logo
279 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
