Question about Panasonic PT-61LCX66 Television
My TV has tiny pin head blue spots on the screen once you turn it on and they are on all channels.
  • Panasonic Master
  • 5,138 Answers
Light Engine /optical unit Block
Encompass Parts Disrtibution 1-800-638-3328
UED 1-800-648-6657
Posted on Sep 28, 2010
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
I have a kf50we620 and I". Experinceing blue streaks on the left side of the tv. Big blue spot upper left. Tiny blue spots when the tv turns on
it is colour patches.many tv's are this problem set right one or two days automatically.but not clear it than you take a external degauging coil and solve your problem. thank you.
Oct 11, 2010 | Sony Grand WEGA KF-50WE620 Television
I have a shure v-15-5mr phono cartridge with a loose pin on the rear of the body. This is causing the right channel to cut out intermittently. How are the wires connected to the pins and can it be...
You're not going to fix it internally. The guts are made by elves with really tiny fingers. But maybe you could put a drop of epoxy on it to keep it from moving once you find the sweet spot.
V-15. Legendary cartridge from the 70's.
Mar 12, 2010 | Shure Audio Players & Recorders
Small tear drop leak from chrome bathroom radiator, where the joint is, poor weld!
I turned off the radiator and let the leak stop, located the pin head hole, cleaned the tiny area with emery paper, put a spot of flux in the hole then applied a tiny drop of solder. Worked a treat.
Nov 08, 2009 | Google Chrome
Tiny Blue Dots all over scree. Now wont turn on.
is munes the same way, if it is try to clean
back mirror. if that don,t you need to call sony.
because it your eng is bad wicth is whear the pix come from.
Aug 25, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue spots on Sony High Definition 41 inch tv.
There are tiny screens at the top and bottom of the lightbulb (XL2200) that allow air for cooling over the lightbulb. It appears that if air flow is restricted the heat is not able to escape. The light source is in direct proximity to another mirror like device called the integrator lighting system polarization changer element. This may have gotten a little hotter than normal and is changing how the light is passing through to the tiny LCD's which make up the light engine. Creating the small areas of lavender light we are seeing.
I myself have replaced this bulb and now will check every months to vacuum the dirt off the tiny screens.
Apr 26, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue dots and blue screen on Hitatchi 50"
Bad Light Engine Call UED for rebulit one 1-800-648-6657 They are not cheap.
Dec 26, 2008 | LG RU-44SZ51D 44" Rear Projection...
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-61LCX66 Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
