Question about BenQ FP731 17" LCD Monitor
Blank screen xerox monitor going blank after one second...prod number...xm3-19w...help!!
  • Anonymous Feb 07, 2009
    i have the same problem, start fine and same times goes off after 30 min, same times after 2 sec
  • Fuggyman101 Apr 06, 2009
    i have the same problem and its not a driver problem, it's to do with the inverter / power board, and there seems to be only one place on the net that sells parts.
    any info on repairing or a place to buy a new inverter /power board is very much apreciated, the part numbers for this board is:
    PI-190DTLB or 200-000-170DTLBMH
  • 1,031 Answers
Is your Xerox XA7-19i monitor supplied with a fixed DVI-I Single Link cable with Windows Vista?if it has u can connect it via a VGA card which will work with the driver
As a result of this cable configuration recent Nvidia Vista drivers do not detect the monitor causing a blank display and apparent "Hang-up". (Although this is not the case, you simply cannot see what's going on!)
This is a problem that was introduced with the release of new series drivers
Posted on May 24, 2008
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Screen going blank on system boot and on switch off/on
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a fraction of seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 08, 2010 | Sony SDM-HS75 17" LCD Monitor
Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
Xerox
remove both visible screws on back.  Slide front cover off (pushing the glass off, toward its bottom.
Mar 11, 2008 | Xerox XG-91D 19" LCD Monitor
Blank Monitor
Try your monitor on another computer, just to make sure it's the monitor and not a video adapter problem in the computer. It may be possible to fix it if you can find a reliable computer or TV service shop nearby. However, the cost may not be worth it for a 2-year old monitor. Unfortunately, the best solution is probably to buy a new one. : (
Jan 13, 2008 | Computers & Internet
Xerox 19i screen going blank
Does look like a back light or inverter problem Have you got a TV repair shop that can take a look Although your warranty may have gone you can still seek technical support on the web site,
May 27, 2007 | Xerox XA7-192i 19" LCD Monitor
Screen goes blank also.
I too have an LCD Xerox - it worked fine for a while, then kept going blank and going onto standby. Unplugging and reconnecting from both pc and power seems to reset it. It hadn't happened for months but started again the other night when it occurred to me that I had just downloaded MS security updates - I've removed the ones that I downloaded just before it started happening again and the problem seems to be solved. Hope this helps someone.
Dec 19, 2006 | Xerox XG-91D 19" LCD Monitor
LCD Monitor turns off or goes blank after a couple of seconds being on
An all too common problem with lcd's, you would think they would be more reliable after being on the market for years, alas they are not. See if it does the same thing on a friends PC if you are able; if so the you will know the lcd is faulty.
Nov 12, 2006 | ViewSonic VP181s 18.1" LCD Monitor
Monitor comes on, shows the screen for a second then goes blank
The main problem is here is the graghics card its needs to updated and make sure the pins are alright on the display cable. Also you need to uninstall the integreated one that came with the PC first before you install a graghics card. so right now you need to put the display back to the motherboard display then when you have that done then you put it in the grafics card you have then it should something i had the same promblem for awile i couldnt figure it out either. Hope that works for you. Good luck
Nov 08, 2006 | Xerox XA7-192i 19" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
470 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
