Question about Cell Phones
Please describe your how can i format my blackberry 8520 problem cos my key pads aint working it just stats dialing nnnnnnnnn
  • 358 Answers
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Posted on Sep 28, 2010
Hey can you please unlock bb curve 8520 ...imei:357257.04.904092.1
Hi, You can get the unlock code for a Blackberry Curve 8520 from http://www.unlocking4u.com/blackberry-8520-curve/rs6wp9/ at affordable cost.
Here are the steps for unlocking a BB Curve 8520,
1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry 8520 Curve will now be unlocked.
Sep 20, 2012 | RIM BlackBerry Curve 8520 Smartphone
My touchpad doesnt work on my blackberry 8520
Hi
touch pad may hav stop working because of moisture damge threw track pad.
you need to clean your contact(track pad touch contact) by opening your phone.
thanks
Oct 06, 2011 | RIM BlackBerry Curve 8520 Smartphone
My bb 8520 says media card cannot be read. verify that the memory card is formatted. what do me?
The best thing you can try to do is connect the media card to your computer. When you see it show up in "my computer" or "computer" right click on it, and select "format". Make sure the formatting is in either FAT or FAT32. Once that is done, put it back in the phone and try again. If you cannot plug the card into the computer, then use the supplied USB cable for the phone, and plug that in to the computer. On your screen it will ask if you want to sync, enable mass storage or charge only, make sure you select enable mass storage. If you do this your card should be readable on the computer and then you can format it using the same method I described. Just note that if your blackberry gets plugged in, it will show up with 2 "storage cards". One of them is the memory that is on the phone and the other is the actual media card. Make sure it is the media card that you have selected to format.
Sep 13, 2011 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 8520 keys wont work the track pad is working but i cant select
Hello. THis is a common problem. please take it to a nearby repair shop and ask for it to be CLEANED. the inner keypad needs cleaning/replacement. The cost is low generally, and takes a few minutes.
Thank you for using Fixya
Aug 31, 2011 | Blackberry Cell Phones
Unlocking cods for cell phone
To get the Unlock code You can reach here
http://www.onlinegsmunlock.com/blackberry-8520-curve/rs7wp9/ and Unlock the Mobile from the Network lock...
Dec 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
Can unlocked blackberry 8520 be upgraded to the recent framework? After upgradation is it still in the unlocked mode?
Hello
you can unlock your Blackberry Storm 9530 SmartphoneStorm 9530 Smart phone.by simple entering unlock code through key pad,after unlock your Blackberry you can use it with any GSM SIM card around the world.I know this trust fully Blackberry unlock code provider. I hope this Blackberryunlock code will very help full for you.
Nov 18, 2010 | RIM BlackBerry Storm 9530 Smartphone
Free Mep Code For Blackberry curve 8250?! please
The following are the steps all we need to take to unlock the code for BlackBerry Curve 8250/8520 if we happened to get our BlackBerry Curve 8250/8520 code locked.
Turn on the Blackberry Curve 8250/8520 with the current network/service provider's SIM card.
Using the menu, go to Settings Menu
Oct 05, 2010 | Cell Phones
BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
May 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
Track pad not working 0on 8520 blackberry
You need a replacement trackpad. If you want us to help fix your phone for you email us at blackberryrepairshop@gmail.com
May 12, 2010 | RIM BlackBerry Curve 8520 Smartphone
I had same problem and now solve it :) Just disassembly the phone and check trackpad connector ( just take it off and return on its place ) It will work perfektly :) U can find more videos for replacing trackpad on UTube .
Mar 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
Cell Phones Logo
245 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
