Question about HP Officejet 5610 All-In-One InkJet Printer
Hi there, When I am about to scan, I click HP Solution Center, a pop-out window says "No HP devices have been detected, HP Solution Center will close now." How to solve this? Thanks & Best Regards
  • HP Master
  • 1,679 Answers
This means there are few HP files missing that connects your printer and PC for scanning.
First, Make sure you are able to make copy from the printer in standalone mode.
IF yes, there are 2 ways you can fix this issue. One would be to follow the steps given in the link below and other the manual steps if you are good in computers
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02468684&cc=us&lc=en&dlc=en&product=441125
Or
1. Disconnect the USB Cable from PC
2. Run the Software disk of HP Printer and click Uninstall
Or
Open Control panel and open Add/remove programs ( or ) Programs and features and delete the HP Printer software drivers that you find ( Do not try this if you are using HP computer or laptop )
3. Click on Uninstall option
4. Restart the PC
5. Download the latest drivers from HP Website and start the installation
[ CONNECT THE PRINTER ONLY WHEN THE SOFTWARE PROMPTS YOU TO ]
to download the latest software drivers for your PC, click on the link below choosing the operating system you are using.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&lang=en&cc=us
If you are not able to make copy from standalone, Check if the Ink level and make sure the printer is aligned.
* Please rate this answer with thumbs up and comment if answered to your satisfaction
Posted on Sep 28, 2010
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
Scanning with an Officejet J3680
Click Start , and then click Run .
In the Open text box, type msconfig , and then click OK .
In the System Configuration Utility window, click the Startup tab.
Search the list for HP Digital Imaging Monitor . tick the box.
If HP Digital Imaging Monitor is not on the list,
the driver was not correctly installed and You need to reinstall the software.
Open HP Solution Center with one of the following methods.
On the Windows desktop, double-click the HP Solution Center icon
On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
If more than one HP device is installed, click the tab for the All-in-One product.
Click Settings .
Click Scan Settings and Preferences .
Click Scan to... Setup .
Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the
Front Panel Destination List to populate after you turn on the printer or computer.
If the Front Panel Destination List contains valid scan destinations,
you need to reinstall the software.
If the Front Panel Destination List is empty, continue with this procedure.
Click each program to include on the Scan To list.
Click the Add arrow.
Click OK .
Scan a document using the Scan To button on the front panel.
If the scan fails, try to scan using the HP Solution Center Scan button.
If the scan still fails, re-install the software.
Hope this helps
Ric.
Apr 17, 2009 | HP J3680 Officejet All In One Printer
HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
No HP devices detected. HP Solutions Center will close now.
when it hangs,right click the task bar and open task manager and from the process tab stop the file wrapper.
In device manager click on view and select show hidden devices.
U will see and imaging device keep updating it and
Oct 22, 2008 | Office Equipment & Supplies
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab.
    NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Hp 2700 series all in one printer scanning issues
Hi .
Let me first explain that the scanning softwareis seperately loaded into the computer which is called as Digital Imaging. Try the step below:
1. try scanning from scanners and cameras - 2 errors might pop up if it does not scan - an error occurred communiating with the scanning device / no HP device detected.
2. start - programs - locate for a software loaded called HP Solution Centre / HP Director.Open the software if loaed and try to scan from there. If its not loaded then insert th installation cd and click on Install more software - full.
3. In HP solution Centre / Director click setting - scan settings - scan to ..... setup - see that both the columns of front panel and available destination list should be having some icons into it (you can add and delete from any column as desired - but none should be empty)
Click the link below to ssist you with relevant troubleshooting -
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=40990&lc=en&cc=us&dlc=en&product=420428&lang=en
If none of the above work then try uninstalling and re-installing the printer software all over again
Apr 13, 2008 | HP Photosmart 2710 All-In-One InkJet...
Scanner
First check whether you are able to scan from hp solution center.
then check whether you are able to scan from ms paint.
to check: open paint, click on file-->from scanners and camera.
if it is scanning then proceed to the following steps or else uninstall the software and reinstall it
Step 1:
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Step 2:
    2. On the Windows desktop, double-click the HP Solution Center icon.
    1. If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
    2. Click Settings .
  • If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  • Click each program to include on the Scan To list.
  • Click the Add arrow.
  • Click OK .
  • Scan a document using the Scan To button on the front panel.
  • If the scan fails, try to scan using the HP Solution Center Scan button.
  • If the above steps doesnt solve your problem, please uninstall the software and reinstall it.
    Mar 14, 2008 | HP PSC 1610v All-in-One Printer
    My scanner always scans with blurry lines across scanned images from it
    I believe that you are trying to scan via HP solution center.
    Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
    If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
    3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
    4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
    7.Try scanning.Please let me know after following the steps!
    Feb 09, 2008 | HP Photosmart C3135 All-In-One InkJet...
    HP Officejet 5610 All-In-One InkJet Printer Logo
    53 people viewed this question
    Ben Johnson
