Question about Brother HL-2040 Laser Printer
Problems with toner and drum Error indicator Brother HL 2035
5 Suggested Answers
SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Dec 08, 2008
  • 5 Answers
SOURCE: HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Posted on Jul 17, 2008
Adi_Taticu
  • 71 Answers
SOURCE: I've recently installed a new Brother toner, but
DRUM UNIT "spent"
It can be reset if the printing quality is good
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Oct 09, 2009
Testimonial: "A first rate resolving of the drum problem on my Brother HL 5140. Thanks very much, Fixya."
  • 114 Answers
SOURCE: message "toner or cartage or drum error of brother laser printer"
replace both drum and toner .
Posted on Jul 18, 2010
Cleaning printhead Brother HL2035
Ideally the drum should be disassembled, the brush inside should be cleaned (carefully as it will be full of toner and dust), and the drum cylinder cleaned with isopropyl alcohol and a cotton ball (also carefully as it's fragile) if the coating on the cylinder is scratched or worn thin and uneven, you should replace it. When reassembled, clean the corona wire with the slider and ensure the sloder is returned to the resting position.
Mar 14, 2014 | Brother Hl-2035 Drum
There is no HL-2035 listed on Brother's website. Please double check you model number and follow up with me. Why do you want to clean the printhead? Brother Solutions Center Search Result
How do I reset the consumables counter on myBrother HL-2035 printer printer
1.) Turn the printer off.
2.) Hold the 'go' button while turning the printer on. All panel lights should be on.
3.) Release the 'go' button once all lights are off.
4. )Press the 'go' button 2 times.
5.) Pause.
6.) Press the 'go' button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your "low toner" light should be fixed.
Jun 16, 2013 | Brother Hl-2035 Drum
When trying to register my brother hl2035 printer i get error code 406
hi,
pls try with the below site
PRINTER, EPSON - STYLUS BX300F - EPSON, EPSON - STYLUS SX215 - EPSON
Error communicating with the server. Show Details Show Details ... View My Account View My Account; My Orders My Orders; My Profile; My Address Book. About Us ... To login or register securely click here ..... BROTHER Part No HL-2035. Order Code CS16669, PRINTER, MONO LASER HL-2035, BROTHER - HL-2035 - BROTHER ...
cpc.farnell.com/1/1/index410.html - United Kingdom - Cached
May 30, 2011 | Brother Office Equipment & Supplies
My brother printer HL-2035 keeps jamming the paper. I have changed the drum and toner and the drum light is still on when it prints. Can you help please?
I think you need to reset the consumables counter to clear the drum warning light as the printer can't automatically recognise new parts. If you've bought a genuine Brother drum unit there will be detailed instructions inside the box as to how you reset it which usually involves holding down the only button whilst switching the machine on. As for the paper jams, it could be something as simple as loading less paper and fanning it to get some air between the sheets before sliding it into the tray or it could be that you need to buy a new paper feed kit which is fairly cheap and easy to install.
Oct 07, 2010 | Brother HL-2030 Laser Printer
My HL-2140 brother laser printer is flashing a red error
1>If the toner lite is blinking , it's mean the toner life near to end. In these case please replace the toner cartridge.
2>f the drum lite is blinking , it's mean the drum life near to end. In these case please replace the drum.
I hope it will help to solve your printer problem.
Feb 09, 2010 | Brother HL 2140 Laser Printer
HL-1240, the alarm light is on, what would be the reasons?
the first alarm light (at the very top) indicate the toner life ends the second light(middle) indicate the drum life ends and the third is for paper jam or print error
Sep 18, 2009 | Brother HL 1240 Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
Brother HL-2040 Laser Printer Logo
2,607 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
