Question about Toshiba Regza 37HL17 37 in. LCD TV
I wish to reset toshiba regza 37wlt68 to default or factory settings how do i do this
I have the same problem mate
Posted on Oct 08, 2010
Toshiba regza no longer receives a an hdmi signal.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 02, 2016 | Toshiba Televison & Video
I have Toshiba Regza 32pb10e LCD TV & I have no color blue in my picture
If you have reset and t to factory default and this problem still persist you will need the services of an electronics technician. It is possible that the motherboard has developed a component fault
Jun 08, 2015 | Toshiba Televison & Video
Very low volume. have to turn up to over 40 to get any kind of volume.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 20, 2015 | Toshiba Regza 46RV535U 46 in. LCD HDTV
How do I solve a power up / switch on problem with a Toshiba TV model REGZA 37WLT68?
may be a bad Capacitor on the motherboard, or its a bad power supply board. upon disassembly look at the Caps (image posted) near where the power goes into the tv. Typically larger ones. if any of them look swollen or burnt, then that is your problem. it must be de sautered and replaced with one of the same specs. if all of them look okay, then you probably need a new power supply board, which should be seperate board from the main board of the tv, depends on the model though. Also, check all around the board, there may be a bad (watch) battery on the board or a bad (glass) fuse.(also imaged)
Feb 22, 2015 | Toshiba Televison & Video
I have tried to Autodesk Toshiba Regza but it is not picking up channels and has message 'please scan channel's on screen. Aerial is attached to outdoor antenna.
Sounds like Tuer fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 25, 2014 | Toshiba Televison & Video
How to turn cc off when its off but stays on!!
Try a factory reset to this set. To reset it to its factory reset [System reset]; you have to enter its service mode, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 22, 2014 | Toshiba REGZA 47HL167 TV
I do not know the reset code for my Toshiba 1080P 42XV505DB tv. I am having trouble setting the Sky remote as I lost my Toshiba tv remote,
You should be able to buy a universal remote to fix this problem.
Can you get into your main menu.? If yes, try reseting to factory default. If asked a pass, try 0000.this should do the trick.
Hope this helps.
Apr 12, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba Regza 37HL17 37 in. LCD TV Logo
1,244 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
