Question about DeLonghi Coffee Makers & Espresso Machines
The coffee machine is not piercing the coffee pods on the front, the rear of the machine is piercing OK.
5 Suggested Answers
  • 67 Answers
SOURCE: part that holds the coffee cups that pierces both
i think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
Posted on Jan 27, 2011
wentlanv
  • 710 Answers
SOURCE: Recently the machine started dispensing
Hi imhofag,
The first thing to do is clean the projections on the piercers. Gunk will build up on them and they need to be cleaned periodically.
I would need your model number in order to help you take it apart.
Please reply if cleaning the projections doesn't help.
Thanks,
Handie Andie
Posted on Jun 12, 2011
SOURCE: The pods are not being
The capsules are not pierced when they are inserted. They are pierced on the back but not in the foil. The foil is pierced when the hot water is injected through the posterior holes and the pressure causes the foil to bulge, thus getting pierced by the grid in the front of the machine. If the capsules are not getting pierced it means that the water is not being injected with enough pressure. This could be due to hard water deposits. Try first to pump the machine by turning it on and then lifting the lever and keeping it raised for a few seconds. If that doesn't work, de-scaling the machine should correct the problem.
Posted on Sep 16, 2011
SOURCE: No coffee comes out, only
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
Posted on Dec 13, 2011
After the pod is put into the machine doesn't pump the water through
had that probleme ( if you check the pin that pierce that k cup or pod ( it has small hole in it take a tooth pick and put it true that hole to get the dried up coffee out ( if that seem to not work ( u can blow in that needle also) and if that dont work take the top off ( screws ) and find the feeding line could full of dried up coffee ... ;) that is your problem
May 14, 2017 | Coffee Makers & Espresso Machines
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
Coming out in short spurt will not coffee cut up
there are a few things that can cause this;
1) You may need to clean the needle in the coffee exit where the coffee pod sits and gets pierced when the top is closed. You do this with a needle, be careful the point of the piercing nozzle is sharp and the needle point is as well.
2) There is also a needle in the cup holder under the pod that cuts the hole for the coffee stream, this needs to be cleaned with the needle.
3) The filter in the water tank may be plugged and needs to be cleaned.
4) The pump may be clogged with lime and scale.
5) The heater element may be scaled with lime.
6) Items #3 to 5), to fix this use DE-scalier, or vinegar solution, the pickling strength works better than household variety, but both are OK.
7) run the cycle for coffee, no pod, 3 times, this should clear the taste of the vinegar.
Hope this is your solution.
Mar 17, 2015 | Keurig B70 Coffee Maker
Why my nespresso c110 cofee machine will not pierce the top of the pod and thereFore no coffee.
Are you using genuine Nespresso capsules? Any other kind will cause the machine to malfunction.
Feb 13, 2015 | Nespresso Coffee Makers & Espresso...
What are coffee pods? Someone told me to use them in my coffee machine?
Some coffee machines have the option to either use ground coffee and filters or coffee pods. These are small, sealed containers that have the ground coffee inside. You insert the pods into the machine and click them into place. The machine pierces a hole and the water drips through. It's a much tidier way to make coffee especially if you don't drink a lot of it, so you don't want a whole jug full, rather just one cup at a time.
Feb 25, 2013 | Home
The pods are not being pierced and the coffee is coming out too weak. Help!
Aug 10, 2011 | Nespresso Essenza D100 Espresso Machine
I do not have a manual. How do I use this thing?
fill the water tank, plug it in, turn it on
open by handle in front, put in a pod, be careful NOT to touch the top there is a NEEDLE to pierce the pod, close it, put your cup under the spout, select cup size and wait. Just takes a minute.
You can also purchase a "my cup" which is a empty gray pod section that replaces the one with the needle and you can then use your own grounds making it cheaper to use.
Jan 11, 2011 | Keurig B60 Coffee Maker
Every light blinks and it won't heat water a braun tassimo coffee maker
just posted this solution to another problem. there is something on the glass bar code reader up where you insert the t-disc - or the water vessel is not properly seated in the base of the coffee maker.
Check both.
Nov 04, 2009 | Braun Tassimo Coffee Maker
Coffee Doesn't Brew
You may have gotten a unit that is minus the piercing apparatus. The little plastic piece with the piercer may come off with the used pod. This never happened to us but my daughter-in-law did, and apparently threw the piercer out with a used pod. They were able to order the part which seems to be easily removable - actually they ordered two while they were at it. Their coffee maker is working just fine.
Mar 18, 2008 | Braun Tassimo Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
