Question about PC Chips P23G Motherboard
Help hi my pc was left on came back to it and nothing ? it will not boot up and nothing lights up ,nothing shows on monitor
    Genius:
  • 2,785 Answers
Check the powersupply unit
Posted on May 24, 2008
Compaq 615 laptop just hung, i removed the battery then tried to boot again but showed nothing
Hi
Not enough information.
It would be helpful to know if this machine running XP, Vista or Win 7.
Can you hear the CPU beep during boot?
Do the lights come/blink on on the front of the laptop?
All this information is important if you want accurate advice to help solve your problem.
If you have a desktop PC monitor available, connect this to the laptop's VGA port and press the Fn (function) key simultaneously with the F5 or F6 key (the key showing 2 monitors) while booting, to send the image to the external monitor.
If you can see images on the external monitor, then your laptop may have (in ascending order of seriousness/cost of repair), an LCD panel inverter fault/failure, a cold cathode backlight fault/failure, an LCD panel fault/failure, a graphics card fault/failure, a motherboard power management system fault/failure, a motherboard fault/failure.
Sorrry to not be able to be more precise.
Hope this helps.
Aug 02, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Have used for 3 1/2 years no problems. 1 day on working great, left for about hour & back to black screen. When computer first starts, I get welcome screen, then nothing the menu lights on right light...
Have you tried it on another computer? if not please do it. Your monitor problem seems with the CPU not booting up properly. You can also try with another monitor on the computer. Please confirm after you are done with the results. Thanks.
Aug 17, 2010 | Gateway FPD2275W LCD Monitor
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Acer One 1542 series.Power on but not boot.
since you reseated the memory, the last two things I would do is remove the hard drive and dvd drive.
If you remove those and you can't get video then the motherboard is bad.
Aug 03, 2009 | Acer Aspire One PC Notebook
Acer One 1542 series not boot
Take out the battery and the mains power, turn the laptop over and remove the ram cover, look for the ram and take it out by pushing the metal lugs outwards so the memory pops up, it's now ready to remove, the ram (memory) looks like this >>>>>>
Once the memory is out look very close in the memory bay for 2 brass triangles, they will be in the shape of a diamond, get a flat head screwdriver and short them 2 pins out, this will clear the CMOS, put the memory back in, turn the laptop over and plug in power & hit the on/off button.
When it comes it will say that bios settings are wrong so go into the bios and set the time and date, save the changes and exit the bios, the computer will restart and hopefully boot up with no more problems.
Hope this helps.
Good luck.
Aspire One, screen shows nothing
I suggest you take it back to your supplier because it woud be under warranty. If you try and fix it yourself at this stage you might void your warranty.
Jan 21, 2009 | Aspire Acer 7520-5071 Notebook
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell wont start up
On the back of the chassis, there are 4 LEDs above the PS2 connections marked ABCD what do they indicate? During the boot process the lights normally flash on and off green, when the boot process is complete, they should all be green GGGG.
If any are Amber then they are indicating a power on self test (POST) failure. AAGG is bad memory for example.
Post the indications
Aug 06, 2008 | Dell Dimension 4600 PC Desktop
Dimension 4500S
hi!,
I hav a solution 4 u . Ur LCD monitor's wires of ur Laptop Has gone loose , U can just give ur lappy 4 a servicing.
byeee........
Mar 08, 2008 | Computers & Internet
Cpu /monitor
Hi, Sounds like video card problem. Try removing, cleaning the gold contacts and re-installing to the slot. If your PC uses an on-board video that shares with the memory, then you have to remove your memory and clean the gold contacts then re-insert back and try again. If cleaning, re-inserting/re-seating does not solve the problem, then perhaps replacement is required. Hope this be of some help/idea. post back how things turned up or should you need further information. good luck and kind regards.
Oct 01, 2007 | Maxtor Hard Drive
PC Chips P23G Motherboard Logo
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
